Contemplating the move from SmartThings to Hubitat and have a question about Dashboards…
I've watched a number of YouTube vids on creating them, and "assume" that clicking on various elements call a URL (either via the cloud or directly to the hub). So my question is "can you call these URLs from anywhere?" (from a Shell script or AppleScript for instance).
Might help if you gave a specific example. You can do pretty much anything you want but how you go about it depends on what you're trying to do.
Just something simple like…
#!/bin/sh
curl <URL>
I think I remember hearing the dashboard uses a web socket to keep its elements updated.
If you want to interact with a device there is the maker api that exposes a url and a http get can be used as a trigger in rule machine.
It's a good thing your taking your time. By the time you decide HE is the one for you, they might be back in stock
There are all kinds of dashboard solution for HE and if your looking to make something unique they have made it easy to do that as well via maker like @potts.mike mentioned.
Have you checked out the Show Off thread? Long post, but lots of samples of different ways people interact with HE.
Are you wanting to display a dashboard that is launched from a script? Or are you trying to mine/manipulate the data from a dashboard page?
If the former, the Hubitat Dashboard is just a web app running on the Hub, which can be accessed by any compatible web browser either using a LAN URL or a CLOUD URL. The cloud URL will work even if you’re on your home LAN. If you’re script is launching a browser with the Dashboard URL, I would think that should work.
If the latter, I would recommend you take a look at the Hubitat Maker API, which implements a RESTful API, transferring JSON back and forth. It works very well and can be called via the iOS Shortcuts App’s scripts to get data about a device, or issue commands to a device.
Developers have even implemented full integrations using the MakerAPI app for things like HomeBridge and The Home Remote.
Hope this helps. If you explain What you’d like to accomplish, I am sure the community will be happy to assist.
Thanks… I have built a web server that executes scripts (shell, AppleScript, Python, Automator workflows, or any combination of the above). In SmartThings, I could control devices in such scripts by building URL tokens for them, ala…
do shell script "curl https://graph.api.smartthings.com/api/smartapps/installations/xxx-xxx-xxx/devices/mySwitches/xxx-xxx-xxx/off?access_token=xxx-xxx-xxx"
It is kind of a pain creating the tokens, but they work (and I only need to do it once). Just looking to do a similar thing with devices that are paired with the HE hub (ideally locally).
I think the Hubitat Maker API will be your best, simplest method of integrating custom apps running on other hardware with Hubitat. It works very well. You can also supply a URL to have Maker API call with unsolicited device status updates, to keep your custom application up to date without any need for polling the hub.
Thanks, I appreciate all of your comments!
