I can only get false. Iāve been confused my this for months
Is it an iOS mobile bug maybe
One idea would be to change the trigger to when the ābattery level changesā instead of every 10 minutes. Doing so will then run the rule only when the battery level changes.
Youāll also want to only change the outlet to on if it is already off. Otherwise youāll always be sending commands to the outlet, even if not required.
