How can I tell if a bulb repeats?
I have some Innr bulbs and I've been looking at the routing table and doesn't make a whole lot of sense to me
YOUR_HUB_IP/hub/zigbee/getChildAndRouteInfo
These are the routing devices. All routing device will have a 'Neighbor Table Entry' listing with LQI, inCost, and outCost
You want a LQI of 255 (best) and Cost at 1 . If your LQI is low or Costs are high, your mesh needs help. I add a few outlets and my Zigbee mesh is much better.
If you check out my " Main Floor Alarm" you can see he is not a good repeater. Know it's location relative to everything, I know it is a bad device, and it is going to get replaced.
So this is my table. The bulbs in question are the bathroom ones I can see them there.
Child Data
child:[Aqara, 507A, type:EMBER_SLEEPY_END_DEVICE]
[Dressing Room Light 3, 02F6], LQI:255, age:4, inCost:1, outCost:1
[Bathroom 1, 7AD7], LQI:253, age:4, inCost:3, outCost:7
[Porch Plug, 8F18], LQI:254, age:4, inCost:1, outCost:5
[Bathroom 4, 98D5], LQI:254, age:3, inCost:1, outCost:4
[Porch Light, 9AFD], LQI:0, age:4, inCost:7, outCost:7
[Bathroom 3, 9CA5], LQI:254, age:4, inCost:1, outCost:7
[Dressing Room Light 2, 9DF6], LQI:255, age:2, inCost:1, outCost:0
[Kitchen Light 2, A694], LQI:245, age:0, inCost:5, outCost:0
[Master Bedroom Lamp (S), B4F9], LQI:252, age:4, inCost:3, outCost:7
[Master Bedroom Plug, B983], LQI:247, age:4, inCost:3, outCost:5
[Theo's Room Light, BD84], LQI:244, age:4, inCost:5, outCost:5
[Dressing Room Light 1, BE52], LQI:255, age:3, inCost:1, outCost:0
[Bathroom 2, CC7E], LQI:253, age:4, inCost:3, outCost:7
[Study Light, E470], LQI:244, age:4, inCost:5, outCost:5
[Kitchen Light 1, F6C6], LQI:255, age:1, inCost:1, outCost:0
[Pantry Switch, FCF4], LQI:255, age:3, inCost:1, outCost:5
Route Table Entry
status:Active, age:64, routeRecordState:0, concentratorType:None, [DoorBell Button, 39B8] via [Dressing Room Light 3, 02F6]
status:Unused
status:Unused
status:Active, age:64, routeRecordState:0, concentratorType:None, [Master Bedroom Button, 4017] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Outside Light, 1E66] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Lounge Door Sensor, AB07] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Bathroom 4, 98D5] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Kitchen Door Sensor, C8A7] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Lounge Motion Sensor , 8D26] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Kitchen Light 3, A81D] via [Dressing Room Light 1, BE52]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Study Light, E470] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Lounge Side Light 1, 19F0] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Lounge Side Light 2, AEF4] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [LED lights, 9478] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Toilet Light, A5B2] via [Dressing Room Light 3, 02F6]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Kitchen Motion Sensor , 9E2E] via [Dressing Room Light 3, 02F6]
and they are crappy ones at that. sorry to tell ya. Your other devices look good, but no way to tell device not to use them. You can see the the routing tables they are being used unfortunately. You could put them on a separate hub if you have issue with your zigbee network. Those numbers are not good.
Oh wait the bathroom ones look ok but the cost are still way high.
To be honest I don't have any issues with my mesh I was just trying to work out if the Innr bulbs repeat. I have Sengled which I know don't, just wasn't sure on Innr
from what I have seen/read most all bulbs, other than Sengled repeat (poorly), wich is why I try to stick with just Sengled. As long as they aren't messing up other devices. Just know where you weak links might be if you do have issues.
Yeah I try to buy Sengled as much as possible. But their GU10s are 15gbp each
good stuff is rarely cheep. I keep the Sengled stuff I want on a camelcamelcamel.com watch list, and buy them used, or on sale whenever possible. I just installed some "used" candelabra bulbs and they work great for $6 off.
FYI, if you do end up finding them problematic, Innr bulbs also work fine on a Hue Bridge (I have a couple I've tested various things with).
I may be moving to hue for bulbs as I keep installing more and more and just venturing into LEDs
I've had a lot of luck finding the Feit color bulbs and Tuya Converting them to Tasmota. The Tasmota-HE integration from @marcus is awesome. for under $11 each they are 100% local, and have fantastic features such as syncing with a simple multcast setup.
If you got the route, open the box in the store (easy - does not damage it) and look at the bulb. Look for a 19-xx-xx manufacture code. If it says 20-xx-xx do not get. It will not work.
OK - didn't know we could do that and it's very cool!
PS; my mesh is strong :slight_smile:
