It works on my google mini speakers, but the audio level is low. Is there a way to adjust this when it is played? Alternatively, is there a way to play an audio file from a notification? I see that you can adjust the "Spoken text"
Note that the volume will remain at that level even after it is done playing, so you might want to have another command with delay to reduce the volume as necessary…
I’m not sure I understand your response - Are you saying that when you chose “Control Music Player, Volum…”, then the next drop down doesn’t have a “Set Volume” option?
