I recently installed a Honeywell T6 pro z wave thermostat and utilizing the Hubitat Thermostat Scheduler app and the advanced driver.
My issue is I had the Mode on the thermostat and Scheduler app set to HEAT. The other day on the thermostat, I went to MODE and changed to COOL. Today I checked the thermostat and it reverted back to HEAT. The Scheduler app also was on HEAT. When I changed to COOL in the app then the thermostat mode also changed and stayed on cool.
My question is if I change the mode on the thermostat shouldn't that also change the mode in Scheduler app? Presently it doesn't. I may be wrong but I had a Go Control thermostat before the Honeywell and when I changed the mode on it, the scheduler app also changed.
Much appreciated any explanation.
Tony
