Has anyone found a good Zwave remote t-stat that works with the Honeywell T6 Pro?
Can you describe what you want in more detail? FWIW, Honeywell makes a z-wave+ version of the T6 Pro.
Are you looking for that, or are you looking for remote sensors that work with the Honeywell T6?
I am using the Honeywell TH6320ZW2003 T6 Pro so zwave. We have a single zone on the 1st floor but the bed rooms are always cool at night so want to add a sensor to override if those areas get too cool at night, summer and cooling is not an issue. Thought this might be the easiest way but Honeywell does not make a compatible wireless sensor
Add any Hubitat-compatible temperature sensor you want to the bedrooms, and then control your thermostat using the built-in app called "Thermostat Controller".
