Currently using the "Advanced Honeywell T6 Pro Thermostat" driver. Bought and installed the Honeywell outdoor air temperature sensor. Is there anywhere on the physical thermostat itself or on the device details page where you can see the current reading of this outdoor sensor?
I had an old Trane (not smart). It displayed the 2nd sensor on the screen, although I don't recall where. The screen layout was almost exactly the same as the Honeywell T6.
Have you enabled the 2nd sensor in the thermostat menu? Accessed through the screen. I think hold the "menu" icon for 10 seconds to get into the detailed setup options. You will have to enable the 2nd sensor and tell it if the 2nd is indoor or outdoor.
Definitely have it enabled and working. As I have a duel fuel system (heat pump and gas furnace). The thermostat is set to Lock out the Heat Pump compressor when the outdoor temperature drops below a set temperature. This is working, so the the outdoor temp sensor must be working (I enabled it in the t-stat menu). Having said all this, it would be nice to know what the outdoor air temp sensor is reading, either through the thermostat screen itself, or through the HE device driver.
I took a quick look at the instructions that show the Z-Wave capabilities. I didn't see anything that looked like a 2nd temperature. Perhaps one of the Hubitat guys have a suggestion.
I'd be interested to know how to read the outdoor sensor temperature as well, did you find out a driver or a way to do it? Thanks.
