Hello.
\I recently switched to the built-in driver for the Honeywell T6 Pro, and I am getting the following error message in my log:
Is there something that I should be doing?
Hello.
Looks like it is still holding the schedule from my community version..
Drop this in driver code and switch to it then click clearSchedule
metadata {
definition (name: "Scheduled Job Cleanup", namespace: "djdizzyd", author: "Bryan Copeland") {
capability "Actuator"
command "clearSchedule"
preferences {
void clearSchedule() {
unshedule()
Unfortunately, I was unable to put that code into your community driver. I just couldn't get it to work.
Is there some other way to initialize the driver/device?
I think Bryan meant for you to create a new driver with that code. Then use that new driver to clear schedules before switching to the built-in driver.
That's the way I understood it also.
The problem was that when I added that code to the community driver, it stopped working!
Donβt add it to the community driver. Create a new driver ...
Aha....
Let me try that...
I'll let you know.
Thanks....
Right. It is a temporary utility driver to clear out the schedules so you can go back to the built-in driver without the errors
@bcopeland
Sorry for the delay.
When I use that temporary driver, I get the following error message in my logs:
(Sorry for not responding earlier).
Sorry typo..
Should be: unschedule()
unschedule()
That error is just saying it got a zwave packet and the temp driver has no parse method..
OK.
So, I'll assume everything is OK.
Thanks for all your assistance.
