Hi all,
I have two WX300 switches I wish to setup in a 3-way configuration on one dimmable light. I want to use the default dimmer setup of the WX300, which utilizes the 7 LEDs to display the dimmer level. But due to the fact that the switches are not physically close to each other, I am wondering if I can setup a rule so the 'addon' WX300 switch can display the same LED dim levels from the master WX300 switch.
I figure this needs to be setup as a rule, because from everything I've seen the 'addon' switch in a 3-way configuration keeps no knowledge of state of the load - and is only sending the command to the master switch.
