It sounds like you included the device with S2, which is fine except that I don't know if Coda's driver was written to support that (it's pretty new to Hubitat, and what you'd see are commands failing to send from the hub to the device). Someone asked about this in a thread recently, and I did a bit of work to port a SmartThings driver someone found:
Alternatively, if you don't need all the extra features (e.g., all five taps), Hubitat has a built-in driver that should work for you too. Maybe one of these ideas will help!
