Had HomeKit working. Power hiccup and now home app shows all not responding. My he is on a back up power supply. I rebooted the he just to make sure it was ok. Rebooted the Apple TV serving as hub. I went in to HomeKit integration app and at the bottom did the re-add all devices.
Any advice on how to fix?
Do you mean restart integration or unpair all controllers? If you did the latter, there should have been a warning popup that you need to re-pair the HE hub to Apple Home, in which case I think you will have to delete the bridge in the Home app and add it back in.
After trying everything I could think of I ended up deleting it from HomeKit and setting it up again.
All is working as it should.
