I've been on Homebridge for years and had Hubitat integrated via Maker API. I decided to give the new HomeKit integration a try. First off... thanks for this!
The issue i'm having is with Samsung's Zigbee buttons. I am able to add the buttons and advertise them to HomeKit. They show up as expected.
In the Home app I can add ACTIONS -- single press, double press, long press -- but I can't get them to work. I see the presses in Hubitat debug logs, but they don't make it to HomeKit.
As a workaround, I created virtual buttons and shared those with HomeKit then created rules to translate the physical press to virtual press, then assigned the press ACTIONS in Home to the virtual buttons. And that works perfectly for some reason.
This all worked in Maker API. Any thoughts?
Thanks!
Jad
