Hello,
I have a C8 with v2.3.8.140 and the Homekit integration. Since few weeks my Homekit integration doesn't work anymore and I see the message No Device Responses.
I reboot my HE and then everything will work again.
This problem seems to happen every hours.
Do you have a solution for it?
Thank you
I found my issue by myself - My HE was connected through Wifi and Ethernet which seemed to create conflicts. I removed the Wifi connection which seems to remove the issue. Homekit is now working properly.
Thank you
Thank you for sharing your solution. This may help others with the same issue.
