Hi,
I recently purchased a C-7 when I saw that Habitat had HomeKit Integration now but I'm having a lot of trouble with it. I've searched the forums and tried a bunch of different things, but I just can't seem to get it to work consistently and getting close to just moving everything back to using the Ring as my Z-Wave hub, reaching out to the forums for help and hoping I can sort it out as it seems promising.
My problem(s):
Alexa has a delay in which it is "Waiting for Hubitat" Once it initializes, it's blazing fast but it seems the Hubitat hub goes into a sleep mode of sorts after some time and causes the delay again if not used after a period of time.
Siri/Homekit Integration works well...until again it goes into the sleep/idle mode. Upon initial pairing, everything works wonderfully. The voice commands, the touch screens, the rules, etc. However after some time everything stops responding and shows "No Response" in HomeKit.
Things I've tried:
- Rebooted the Hubitat hub (ethernet connected)
- Rebooted the AppleTV (ethernet connected)
- Rebooted the Alexa/Echo Dots (5Ghz)
- Relaxed home hub pairing security
- Made sure everything was marked as a Switch
- Restarted Integration
- Reset QR and pairing code
They all get it to work in some form temporarily, but it seems if I leave my devices alone and it goes idle, it stops responding again.
Any ideas?
