Hi Community,
I was successfully able to pair an Aeotec Recessed Door Sensor 7 to my Hubitat and expose it to Homebridge using the Maker API app. The accessory in Homebridge looks perfectly integrated and the Open/Closed state is reported accurately and swiftly.
Please note that I am also using the Hubitat Maker API app to expose my Schlage BE468/BE469 Lock.
I previously installed the Homebridge Hubitat Makerapi plugin on Homebridge to expose my Schlage BE468/BE469 Lock to HomeKit, and it works fineāthere is a slight delay with double iOS notifications but works as expected.
I expected the Aeotec Recessed Door Sensor 7 to just show up in HomeKit due to the Habitat Hub -> Hubitat Maker API -> Homebridge -> Homebridge Hubitat Makerapi plugin integration. Unfortunately it is not showing up in HomeKit.
I am not sure how I can tackle this differently. Any pointers would be very helpful!
Technical Details:
Habitat
- Hubitat ElevationĀ® Platform Version: 2.3.0.113
- Hardware Version: Rev C-7
Homebridge
- Running on a Raspberry Pi 4 Model B 8GB RAM
- OS Raspbian GNU/Linux Buster (10)
- homebridge v1.3.8
- Homebridge Hubitat Makerapi homebridge-hubitat-makerapi v0.4.15
- Homebridge Hubitat Makerapi Config
{ "platform": "Hubitat-MakerAPI", "name": "Hubitat MakerAPI", "app_url": "http://192.168.*.*/apps/api/11", "access_token": "********-****-****-****-************", "local_ip": "192.168.*.*", "local_port": 20010, "mode_switches": false, "hsm": false, "debug": false, "logFile": { "enabled": true, "path": "", "file": "", "compress": true, "keep": 5, "size": "10m" } }
