Homekit Controller and WIFI T6 Resideo Thermostat
Hi All,
I could not get my WiFI (NOT Z-Wave) T6 to pair, even though it showed up in the app as available to pair, and was previously linked directly to Homekit. Has anyone else tried or been succesful? Any tips would be appreciated!
Cheers!
I discovered that the implementation of homekit on Hubitat is not all inclusive. When I attempted to change my Abode security system integration from a cloud gateway to Homekit, the only things which could be recognized were cameras and the abode itself. None of the sensors showed up. Since I have their contact sensors woven into my rules I backed out of it. Could be that the subset of homekit Hubitat does support does not include your T6 wifi. The T6 z-wave version works very well though.
Thanks @croweflight. Yes it's probably not compatible. Still, it was worth trying so I could ditch the Resideo App! :slight_smile:
May still work through cloud integration with Resideo. Or Use Package Manager. Maybe their is an API driver integration which works.
The issue is that when pairing to the homekit controller in Hubitat it doesn't trigger the thermostat to generate the code you need to pair. I gave up trying to get it to work.
