I installed home assistant and discovered all the devices (wireless blinds through Tuya), they all work separately, If I select one and set it at 25%, it goes to 25%. If I set it to 0, it goes to 0, any device.
the problem is when I setup Rule Machine to run at sunset, only one or two blinds move.
I get no errors on the logs: app:2302023-02-20 07:12:26.927 PMinfoDelay Over: Close: Family 3 Curtain, kitchen Curtain, Den Curtain, Master Curtain, Guest 1 Curtain, Guest 2 Curtain, Guest 3 Curtain, Family 1 Curtain, Family 2 Curtain
app:2302023-02-20 07:12:23.881 PMinfoAction: Close: Family 3 Curtain, kitchen Curtain, Den Curtain, Master Curtain, Guest 1 Curtain, Guest 2 Curtain, Guest 3 Curtain, Family 1 Curtain, Family 2 Curtain --> delayed: 0:00:03
I even setup delays in case the events were being lost by going together, I separated the devices into different lines of the same rule, I don't know what else to try.
Can someone help me troubleshoot this?
Am I trying to do a lot more than this is supposed to be doing?
If I’m reading your log correctly you are reissueing the same command to the same 9 devices after a 3 second delay. You may want to try metering the commands so you add a pause in between the device commands like below
Another option to try is to do 4 devices in the first run and 5 devices in the delayed run, so your not telling 9 devices to change state at the same time.
That way they are still all delayed at the same time. Rule machine does not stop processing between scheduling delays. So they are all schedule to run in 3 seconds.
As @sidjohn1 suggested, the metering option would put a 3 sec between the actions.
I would say it would take a lot more then that to overload RM. But if you intend to run these 3 rules at the same time it is pretty much the same as all in one rule.
It did the same thing with the metering and with the separate groups of blinds. it has to do with the scheduling, it works fine when I run the rules by themselves.
