Looking for an option to intergrate my hikvision camera motion (via the output alarm - wired) to a zwave devices suitable for HE. i.e. looking for an item that can convert a hard wired signal to zwave?
It is a very low output on the cameras and will have to check exact specs on this.
The fibaro one looks like an option I may have to test. I'm in Australia so zwave is limited to mostly fibaro, goap and aeotec. I was hoping there maybe something I have not yet seen. @vjv not sure on the output yet. I will have to look into it. If you find out, please let me know.
If the software you are using has to option to set a motion alert via a web / http call, then it may very well be cheaper & easier. Since you are running everything local, you are also not 'Net dependent. [Blue Iris has this option, but pretty much all worth their salt do) Used alongside the Maker API app, it has proven to be 100% reliable for me.
It has been several years since I installed BI, but I recall the initial install is a trial version for 30 days. Please correct me if I am wrong. Download Blue Iris
