I'd like to use a local variable to store the HH:MM:SS value for a delay timer. I see an option for Date/Time, but when I delete the date portion the variable is reduced to two values. Can't tell if it's HH:MM or MM:SS, but regardless it won't work for a delay that's expecting HH:MM:SS. Anyone have a solution?
It's HH:MM - Could always store it as string, but not sure how your delay time is going to like that either.
Note that, internally at least, DateTime variables are capable of millisecond precision:
The question boils down to, "How do I assign the MM:SS.mmm value I need?"
Clue: Epoch Time ◄— no promises here, as I've never actually seen a DateTime variable displayed with Seconds in the context you're working with . . .
FWIW, running this quick test in RM to calculate the "Time Difference" between two timestamps around ~70 seconds apart, shows that the quantity is being rounded to the nearest minute:
Note that using a local variable of type Number or Decimal works fine (at least will not throw an error in the Logs) if you apply it this way in RM5.1:
I submit that to you for further testing with your own setup.
Bear in mind that in this arrangement, Delay will be taken to mean Seconds, so a value of 1 will delay the action by exactly 1 second.
Thanks. That works!
