I have seen this problem with lots of equipment.. DB corruption due to spikes caused by other equipment plugged into the same extension lead or directly from the mains supply
It got so bad at my home that I put in a full system to smooth the mains in most of my house.
Hardly. I'd just like to stop wasting hours on something that never seems to get resolved and leads to basically nothing working reliably. It's difficult to be positive with this situation when the hub is now seizing or slowing up often, even with reboots each night. I've invested thousands on this and other iot kit and the core system is more or less broken for me at this house.
I bought that dirt cheap battery one that's on this forum a while back but never set it up. Not sure if that would be a good solution but I guess it's worth a try. Will assess tomorrow after another nightly reboot and the new LAN cable and turning the hub over (although it's not running hot). I will also try disabling a few more apps I think, especially if I still see errors.
Yeah that's what I figured. Will press it into service tomorrow I think. One reason I didn't is because I put the hub on a cheap eWeLink socket so that I can kick the hub over as a last resort if I'm away and have an issue. Actually I didn't need to do that, but it was something I wanted to retain. But it's definitely more important to have a properly functioning hub and in all cases so far I've managed to get into the hub (even when away using my RPi) and reboot it through the software/interface.
I've been using hyphens, &/ampersan, quotes, spaces, brackets. Didn't see any issues until this thread made note of it. Any names I've tried for devices or apps have always been accepted without any error message and haven't seemed to cause an issue so my assumption was HE escaped names properly. But you never know the internals...
Sometimes it feels like anything is worth a try with this hub. But I will await a full moon first I think before doing the barking like a dog so that when the neighbours ask I have a valid excuse.
