I converted Barry's code that I use on ST and have posted it here in case anyone wants to use their HEMv2 w/ Hubitat:
Aeon HEMv2+ Code
* Aeon HEMv2+
* Copyright 2014 Barry A. Burke
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Aeon Home Energy Meter v2 (US)
* Author: Barry A. Burke
* Contributors: Brock Haymond: UI updates
* Genesys: Based off of Aeon Smart Meter Code sample provided by SmartThings (2013-05-30). Built on US model
* may also work on international versions (currently reports total values only)
* History:
* 2014-06-13: Massive OverHaul
* - Fixed Configuration (original had byte order of bitstrings backwards
* - Increased reporting frequency to 10s - note that values won't report unless they change
* (they will also report if they exceed limits defined in the settings - currently just using
* the defaults).
* - Added support for Volts & Amps monitoring (was only Power and Energy)
* - Added flexible tile display. Currently only used to show High and Low values since last
* reset (with time stamps).
* - All tiles are attributes, so that their values are preserved when you're not 'watching' the
* meter display
* - Values are formatted to Strings in zwaveEvent parser so that we don't lose decimal values
* in the tile label display conversion
* - Updated fingerprint to match Aeon Home Energy Monitor v2 deviceId & clusters
* - Added colors for Watts and Amps display
* - Changed time format to 24 hour
* 2014-06-17: Tile Tweaks
* - Reworked "decorations:" - current values are no longer "flat"
* - Added colors to current Watts (0-18000) & Amps (0-150)
* - Changed all colors to use same blue-green-orange-red as standard ST temperature guages
* 2014-06-18: Cost calculations
* - Added $/kWh preference
* 2014-09-07: Bug fix & Cleanup
* - Fixed "Unexpected Error" on Refresh tile - (added Refresh Capability)
* - Cleaned up low values - reset to ridiculously high value instead of null
* - Added poll() command/capability (just does a refresh)
* 2014-09-19: GUI Tweaks, HEM v1 alterations (from Brock Haymond)
* - Reworked all tiles for look, color, text formatting, & readability
* 2014-09-20: Added HEMv1 Battery reporting (from Brock Haymond)
* 2014-11-06: Added alternate display of L2 and L2 values instead of Low/High, based on version by Jayant Jhamb
* 2014-11-11: Massive overhaul completed (see GitHub comments for specifics)
metadata {
// Automatically generated. Make future change here.
definition (
namespace: "Green Living",
category: "Green Living",
author: "Barry A. Burke"
capability "Energy Meter"
capability "Power Meter"
capability "Configuration"
capability "Sensor"
capability "Refresh"
capability "Polling"
capability "Battery"
attribute "energy", "string"
attribute "power", "string"
attribute "volts", "string"
attribute "voltage", "string" // We'll deliver both, since the correct one is not defined anywhere
attribute "amps", "string"
attribute "energyDisp", "string"
attribute "energyOne", "string"
attribute "energyTwo", "string"
attribute "powerDisp", "string"
attribute "powerOne", "string"
attribute "powerTwo", "string"
attribute "voltsDisp", "string"
attribute "voltsOne", "string"
attribute "voltsTwo", "string"
attribute "ampsDisp", "string"
attribute "ampsOne", "string"
attribute "ampsTwo", "string"
command "reset"
command "configure"
command "refresh"
command "poll"
command "toggleDisplay"
// v1 fingerprint deviceId: "0x2101", inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
fingerprint deviceId: "0x3101", inClusters: "0x70,0x32,0x60,0x85,0x56,0x72,0x86"
// simulator metadata
simulator {
for (int i = 0; i <= 10000; i += 1000) {
status "power ${i} W": new hubitat.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 33, scale: 2, size: 4).incomingMessage()
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new hubitat.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 33, scale: 0, size: 4).incomingMessage()
// TODO: Add data feeds for Volts and Amps
// tile definitions
tiles {
// Watts row
valueTile("powerDisp", "device.powerDisp") {
state (
"default",
label:'${currentValue} Watts',
foregroundColors:[
[value: 1, color: "#000000"],
[value: 10000, color: "#ffffff"]
foregroundColor: "#000000",
backgroundColors:[
[value: "0", color: "#153591"],
[value: "3000", color: "#1e9cbb"],
[value: "6000", color: "#90d2a7"],
[value: "9000", color: "#44b621"],
[value: "12000", color: "#f1d801"],
[value: "15000", color: "#d04e00"],
[value: "18000", color: "#bc2323"]
/* For low-wattage homes, use these values
[value: "500", color: "#1e9cbb"],
[value: "1000", color: "#90d2a7"],
[value: "1500", color: "#44b621"],
[value: "2000", color: "#f1d801"],
[value: "2500", color: "#d04e00"],
[value: "3000", color: "#bc2323"]
valueTile("powerOne", "device.powerOne") {
state(
"default",
foregroundColors:[
backgroundColors:[
valueTile("powerTwo", "device.powerTwo") {
state(
"default",
foregroundColors:[
backgroundColors:[
// Power row
valueTile("energyDisp", "device.energyDisp") {
state(
"default",
label: '${currentValue}',
backgroundColor: "#ffffff")
valueTile("energyOne", "device.energyOne") {
state(
"default",
valueTile("energyTwo", "device.energyTwo") {
state(
"default",
// Volts row
valueTile("voltsDisp", "device.voltsDisp") {
state(
"default",
label: '${currentValue} Volts',
backgroundColors:[
[value: "115.6", color: "#bc2323"],
[value: "117.8", color: "#D04E00"],
[value: "120.0", color: "#44B621"],
[value: "122.2", color: "#D04E00"],
[value: "124.4", color: "#bc2323"]
valueTile("voltsOne", "device.voltsOne") {
state(
"default",
label:'${currentValue} Volts',
backgroundColors:[
[value: "0", color: "#ffffff"],
valueTile("voltsTwo", "device.voltsTwo") {
state(
"default",
backgroundColors:[
// Amps row
valueTile("ampsDisp", "device.ampsDisp") {
state (
"default",
label: '${currentValue} Amps' ,
color: "#000000",
backgroundColors:[
[value: "25", color: "#1e9cbb"],
[value: "50", color: "#90d2a7"],
[value: "75", color: "#44b621"],
[value: "100", color: "#f1d801"],
[value: "125", color: "#d04e00"],
[value: "150", color: "#bc2323"]
valueTile("ampsOne", "device.ampsOne") {
state(
"default",
label:'${currentValue} Amps',
color: "#000000",
backgroundColors:[
valueTile("ampsTwo", "device.ampsTwo") {
state(
"default",
color: "#000000",
backgroundColors:[
// Controls row
standardTile("reset", "command.reset", inactiveLabel: false) {
state "default", label:'reset', action:"reset", icon: "st.Health & Wellness.health7"
standardTile("refresh", "command.refresh", inactiveLabel: false) {
state "default", label:'refresh', action:"refresh.refresh", icon:"st.secondary.refresh-icon"
standardTile("configure", "command.configure", inactiveLabel: false) {
state "configure", label:'', action: "configure", icon:"st.secondary.configure"
standardTile("toggle", "command.toggleDisplay", inactiveLabel: false) {
state "default", label: "toggle", action: "toggleDisplay", icon: "st.motion.motion.inactive"
/* HEMv1 has a battery; v2 is line-powered */
valueTile("battery", "device.battery", decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
// HEM Version Configuration only needs to be done here - comments to choose what gets displayed
main (["energyDisp","energyTwo",
"ampsDisp","voltsDisp", // Comment out this one for HEMv1
"powerDisp"
details([
"energyOne","energyDisp","energyTwo",
"powerOne","powerDisp","powerTwo",
"ampsOne","ampsDisp","ampsTwo", // Comment out these two lines for HEMv1
"voltsOne","voltsDisp","voltsTwo", // Comment out these two lines for HEMv1
"reset","refresh","toggle",
// "battery", // Include this for HEMv1
"configure"
preferences {
input "kWhCost", "string", title: "\$/kWh (0.16)", description: "0.16", defaultValue: "0.16" as String
input "kWhDelay", "number", title: "kWh report seconds (60)", /* description: "120", */ defaultValue: 120
input "detailDelay", "number", title: "Detail report seconds (30)", /* description: "30", */ defaultValue: 30
def installed() {
state.display = 1
reset() // The order here is important
configure() // Since reports can start coming in even before we finish configure()
refresh()
def updated() {
configure()
resetDisplay()
refresh()
// log.debug "Parse received ${description}"
def result = null
def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result) {
// log.debug "Parse returned ${result?.descriptionText}"
return result
} else {
def zwaveEvent(hubitat.zwave.commands.meterv1.MeterReport cmd) {
def dispValue
def newValue
def formattedValue
def MAX_AMPS = 220
def MAX_WATTS = 24000
def timeString = new Date().format("h:mm a", location.timeZone)
if (cmd.meterType == 33) {
if (cmd.scale == 0) {
newValue = Math.round(cmd.scaledMeterValue * 100) / 100
if (newValue != state.energyValue) {
formattedValue = String.format("%5.2f", newValue)
dispValue = "${formattedValue}\nkWh"
sendEvent(name: "energyDisp", value: dispValue as String, unit: "", descriptionText: "Display Energy: ${newValue} kWh", displayed: false)
state.energyValue = newValue
BigDecimal costDecimal = newValue * ( kWhCost as BigDecimal )
def costDisplay = String.format("%5.2f",costDecimal)
state.costDisp = "Cost\n\$"+costDisplay
if (state.display == 1) { sendEvent(name: "energyTwo", value: state.costDisp, unit: "", descriptionText: "Display Cost: \$${costDisplay}", displayed: false) }
[name: "energy", value: newValue, unit: "kWh", descriptionText: "Total Energy: ${formattedValue} kWh"]
else if (cmd.scale == 1) {
newValue = Math.round( cmd.scaledMeterValue * 100) / 100
dispValue = "${formattedValue}\nkVAh"
sendEvent(name: "energyDisp", value: dispValue as String, unit: "", descriptionText: "Display Energy: ${formattedValue} kVAh", displayed: false)
[name: "energy", value: newValue, unit: "kVAh", descriptionText: "Total Energy: ${formattedValue} kVAh"]
else if (cmd.scale==2) {
newValue = Math.round(cmd.scaledMeterValue) // really not worth the hassle to show decimals for Watts
if (newValue > MAX_WATTS) { return } // Ignore ridiculous values (a 200Amp supply @ 120volts is roughly 24000 watts)
if (newValue != state.powerValue) {
dispValue = newValue+"\nWatts"
sendEvent(name: "powerDisp", value: dispValue as String, unit: "", descriptionText: "Display Power: ${newValue} Watts", displayed: false)
if (newValue < state.powerLow) {
dispValue = newValue+"\n"+timeString
if (state.display == 1) { sendEvent(name: "powerOne", value: dispValue as String, unit: "", descriptionText: "Lowest Power: ${newValue} Watts") }
state.powerLow = newValue
state.powerLowDisp = dispValue
if (newValue > state.powerHigh) {
if (state.display == 1) { sendEvent(name: "powerTwo", value: dispValue as String, unit: "", descriptionText: "Highest Power: ${newValue} Watts") }
state.powerHigh = newValue
state.powerHighDisp = dispValue
state.powerValue = newValue
[name: "power", value: newValue, unit: "W", descriptionText: "Total Power: ${newValue} Watts"]
else if (cmd.meterType == 161) {
if (newValue != state.voltsValue) {
dispValue = "${formattedValue}\nVolts"
sendEvent(name: "voltsDisp", value: dispValue as String, unit: "", descriptionText: "Display Voltage: ${formattedValue} Volts", displayed: false)
if (newValue < state.voltsLow) {
dispValue = formattedValue+"\n"+timeString
if (state.display == 1) { sendEvent(name: "voltsOne", value: dispValue as String, unit: "", descriptionText: "Lowest Voltage: ${formattedValue} Volts") }
state.voltsLow = newValue
state.voltsLowDisp = dispValue
if (newValue > state.voltsHigh) {
if (state.display == 1) { sendEvent(name: "voltsTwo", value: dispValue as String, unit: "", descriptionText: "Highest Voltage: ${formattedValue} Volts") }
state.voltsHigh = newValue
state.voltsHighDisp = dispValue
state.voltsValue = newValue
sendEvent( name: "voltage", value: newValue, unit: "V", descriptionText: "Total Voltage: ${formattedValue} Volts")
[name: "volts", value: newValue, unit: "V", descriptionText: "Total Volts: ${formattedValue} Volts"]
else if (cmd.scale==1) {
if ( newValue > MAX_AMPS) { return } // Ignore silly values for 200Amp service
if (newValue != state.ampsValue) {
dispValue = "${formattedValue}\nAmps"
sendEvent(name: "ampsDisp", value: dispValue as String, unit: "", descriptionText: "Display Current: ${formattedValue} Amps", displayed: false)
if (newValue < state.ampsLow) {
if (state.display == 1) { sendEvent(name: "ampsOne", value: dispValue as String, unit: "", descriptionText: "Lowest Current: ${formattedValue} Amps") }
state.ampsLow = newValue
state.ampsLowDisp = dispValue
if (newValue > state.ampsHigh) {
if (state.display == 1) { sendEvent(name: "ampsTwo", value: dispValue as String, unit: "", descriptionText: "Highest Current: ${formattedValue} Amps") }
state.ampsHigh = newValue
state.ampsHighDisp = dispValue
state.ampsValue = newValue
[name: "amps", value: newValue, unit: "A", descriptionText: "Total Current: ${formattedValue} Amps"]
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
def dispValue
def newValue
def formattedValue
def MAX_AMPS = 220
if (cmd.commandClass == 50) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 1, 0x31: 1]) // can specify command class versions here like in zwave.parse
if (encapsulatedCommand) {
if (cmd.sourceEndPoint == 1) {
if (encapsulatedCommand.scale == 2 ) {
newValue = Math.round(encapsulatedCommand.scaledMeterValue)
formattedValue = newValue as String
dispValue = "${formattedValue}\nWatts"
if (dispValue != state.powerL1Disp) {
state.powerL1Disp = dispValue
if (state.display == 2) {
[name: "powerOne", value: dispValue, unit: "", descriptionText: "L1 Power: ${formattedValue} Watts"]
else {
else if (encapsulatedCommand.scale == 0 ){
newValue = Math.round(encapsulatedCommand.scaledMeterValue * 100) / 100
if (dispValue != state.energyL1Disp) {
state.energyL1Disp = dispValue
[name: "energyOne", value: dispValue, unit: "", descriptionText: "L1 Energy: ${formattedValue} kWh"]
else {
else if (encapsulatedCommand.scale == 1 ){
[name: "energyOne", value: dispValue, unit: "", descriptionText: "L1 Energy: ${formattedValue} kVAh"]
else {
else if (encapsulatedCommand.scale == 5 ) {
if (newValue > MAX_AMPS) { return }
if (dispValue != state.ampsL1Disp) {
state.ampsL1Disp = dispValue
[name: "ampsOne", value: dispValue, unit: "", descriptionText: "L1 Current: ${formattedValue} Amps"]
else {
/* Ignore voltage updates, because they always match the current Total Voltage
else if (encapsulatedCommand.scale == 4 ){
if (dispValue != statevoltsL1Disp) {
state.voltsL1Disp = dispValue
[name: "voltsOne", value:dispValue, unit: "", descriptionText: "L1 Voltage: ${formattedValue} Volts"]
else {
else if (cmd.sourceEndPoint == 2) {
if (encapsulatedCommand.scale == 2 ){
if (newValue > MAX_WATTS ) { return }
if (dispValue != state.powerL2Disp) {
state.powerL2Disp = dispValue
[name: "powerTwo", value: dispValue, unit: "", descriptionText: "L2 Power: ${formattedValue} Watts"]
else {
if (dispValue != state.energyL2Disp) {
state.energyL2Disp = dispValue
[name: "energyTwo", value: dispValue, unit: "", descriptionText: "L2 Energy: ${formattedValue} kWh"]
else {
[name: "energyTwo", value: dispValue, unit: "", descriptionText: "L2 Energy: ${formattedValue} kVAh"]
else {
else if (encapsulatedCommand.scale == 5 ){
if (dispValue != state.ampsL2Disp) {
state.ampsL2Disp = dispValue
[name: "ampsTwo", value: dispValue, unit: "", descriptionText: "L2 Current: ${formattedValue} Amps"]
else {
if (dispValue != statevoltsL2Disp) {
state.voltsL2Disp = dispValue
[name: "voltsTwo", value:dispValue, unit: "", descriptionText: "L2 Voltage: ${formattedValue} Volts"]
else {
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [:]
map.name = "battery"
map.unit = "%"
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} battery is low"
map.isStateChange = true
else {
map.value = cmd.batteryLevel
// log.debug map
return map
def zwaveEvent(hubitat.zwave.Command cmd) {
// Handles all Z-Wave commands we aren't interested in
// log.debug "Unhandled event ${cmd}"
def refresh() { // Request HEMv2 to send us the latest values for the 4 we are tracking
// log.debug "refresh()"
delayBetween([
zwave.meterV2.meterGet(scale: 0).format(), // Change 0 to 1 if international version
zwave.meterV2.meterGet(scale: 2).format(),
zwave.meterV2.meterGet(scale: 4).format(),
zwave.meterV2.meterGet(scale: 5).format()
resetDisplay()
def poll() {
// log.debug "poll()"
refresh()
def toggleDisplay() {
// log.debug "toggleDisplay()"
state.display = 2
else {
state.display = 1
resetDisplay()
def resetDisplay() {
// log.debug "resetDisplay() - energyL1Disp: ${state.energyL1Disp}"
if ( state.display == 1 ) {
sendEvent(name: "voltsOne", value: state.voltsLowDisp, unit: "")
sendEvent(name: "ampsOne", value: state.ampsLowDisp, unit: "")
sendEvent(name: "powerOne", value: state.powerLowDisp, unit: "")
sendEvent(name: "energyOne", value: state.lastResetTime, unit: "")
sendEvent(name: "voltsTwo", value: state.voltsHighDisp, unit: "")
sendEvent(name: "ampsTwo", value: state.ampsHighDisp, unit: "")
sendEvent(name: "powerTwo", value: state.powerHighDisp, unit: "")
sendEvent(name: "energyTwo", value: state.costDisp, unit: "")
else {
sendEvent(name: "voltsOne", value: "L1", unit: "")
sendEvent(name: "ampsOne", value: state.ampsL1Disp, unit: "")
sendEvent(name: "powerOne", value: state.powerL1Disp, unit: "")
sendEvent(name: "energyOne", value: state.energyL1Disp, unit: "")
sendEvent(name: "voltsTwo", value: "L2", unit: "")
sendEvent(name: "ampsTwo", value: state.ampsL2Disp, unit: "")
sendEvent(name: "powerTwo", value: state.powerL2Disp, unit: "")
sendEvent(name: "energyTwo", value: state.energyL2Disp, unit: "")
def reset() {
// log.debug "reset()"
state.energyValue = -1
state.powerValue = -1
state.ampsValue = -1
state.voltsValue = -1
state.powerHigh = 0
state.powerHighDisp = ""
state.powerLow = 99999
state.powerLowDisp = ""
state.ampsHigh = 0
state.ampsHighDisp = ""
state.ampsLow = 999
state.ampsLowDisp = ""
state.voltsHigh = 0
state.voltsHighDisp = ""
state.voltsLow = 999
state.voltsLowDisp = ""
state.energyL1Disp = ""
state.energyL2Disp = ""
state.powerL1Disp = ""
state.powerL2Disp = ""
state.ampsL1Disp = ""
state.ampsL2Disp = ""
state.voltsL1Disp = ""
state.voltsL2Disp = ""
if (!state.display) { state.display = 1 } // Sometimes it appears that installed() isn't called
def dateString = new Date().format("M/d/YY", location.timeZone)
state.lastResetTime = "Since\n"+dateString+"\n"+timeString
state.costDisp = "Cost\n--"
resetDisplay()
sendEvent(name: "energyDisp", value: "", unit: "")
sendEvent(name: "powerDisp", value: "", unit: "")
sendEvent(name: "ampsDisp", value: "", unit: "")
sendEvent(name: "voltsDisp", value: "", unit: "")
// No V1 available
def cmd = delayBetween( [
zwave.meterV2.meterReset().format(), // Reset all values
zwave.meterV2.meterGet(scale: 0).format(), // Request the values we are interested in (0-->1 for kVAh)
], 1000)
cmd
configure()
def configure() {
// log.debug "configure()"
Long kDelay = settings.kWhDelay as Long
Long dDelay = settings.detailDelay as Long
if (kDelay == null) { // Shouldn't have to do this, but there seem to be initialization errors
kDelay = 15
if (dDelay == null) {
dDelay = 15
def cmd = delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: 0).format(), // Disable (=0) selective reporting
// zwave.configurationV1.configurationSet(parameterNumber: 4, size: 2, scaledConfigurationValue: 5).format(), // Don't send whole HEM unless watts have changed by 30
// zwave.configurationV1.configurationSet(parameterNumber: 5, size: 2, scaledConfigurationValue: 5).format(), // Don't send L1 Data unless watts have changed by 15
// zwave.configurationV1.configurationSet(parameterNumber: 6, size: 2, scaledConfigurationValue: 5).format(), // Don't send L2 Data unless watts have changed by 15
// zwave.configurationV1.configurationSet(parameterNumber: 8, size: 1, scaledConfigurationValue: 1).format(), // Or by 5% (whole HEM)
// zwave.configurationV1.configurationSet(parameterNumber: 9, size: 1, scaledConfigurationValue: 1).format(), // Or by 5% (L1)
// zwave.configurationV1.configurationSet(parameterNumber: 10, size: 1, scaledConfigurationValue: 1).format(), // Or by 5% (L2)
// zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 6145).format(), // Whole HEM and L1/L2 power in kWh
// zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: kDelay).format(), // Default every 120 Seconds
// zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 1573646).format(), // L1/L2 for Amps & Watts, Whole HEM for Amps, Watts, & Volts
// zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: dDelay).format(), // Defaul every 30 seconds
// zwave.configurationV1.configurationSet(parameterNumber: 100, size: 1, scaledConfigurationValue: 0).format(), // reset to defaults
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 6149).format(), // All L1/L2 kWh, total Volts & kWh
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 60).format(), // Every 60 seconds
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 1572872).format(), // Amps L1, L2, Total
zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: 30).format(), // every 30 seconds
zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 770).format(), // Power (Watts) L1, L2, Total
zwave.configurationV1.configurationSet(parameterNumber: 113, size: 4, scaledConfigurationValue: 6).format() // every 6 seconds
], 2000)
// log.debug cmd
cmd
