My z-wave shades have stopped working completely. Non operational from Hubitat. All other devices seem to operate normally - no issues.
I only changed two things today...
I installed the Somfy MyLink Hub integration and setup my single Somfy RTS patio awning to work through the MyLink, and I de-commissioned (i.e. removed from my network) the Somfy ZRTSI-II I was previously using to provide z-wave control over that awning.
I upgraded to firmware 2.3.5.145
I've got to guess that #2 somehow broke my z-wave shades - I can't imagine #1 would've done anything to impact them.
Any ideas?
UPDATE...
Was panicking, contemplating restoring a prior version of my firmware, and then decided to do a full shutdown/hub reboot. That seems to have solved the problem. Never happened to me before....probably should've tried the shutdown before I posted. In any event, relieved that everything seems to be back to normal.
