I've been pretty much set with my automations and have not played with RM in a while, so I am having a complete brain fart on how to accomplish what I think should be a pretty easy automation....
I have a simple automation that says when garage entry door (side door not big garage door) opens via contact sensor, lights come on. When door shuts, lights go off in 1 minute. Simple as it gets.
We just put a beer fridge in the garage and since it gets really hot in the garage, we are leaving the side door open for ventilation. This, the lights are staying on.
I want to create a rule that either:
(a) enables a virtual switch [on] to disable that simple rule after XX minutes of the contact/door being open and will disable the switch [off] when the contact/door is closed again
OR
(b) create a boolean that says something like "if contact open for more than XX minutes, then enable [on] virtual switch" and "if contact closed, re-enable original simple rule"
I can't for the life of me figure out the XX minutes part so that the lights go off when the door is opened for XX minutes. Suggestions?
Do you have other triggers? Such as motion? or another door? I've already got this rule in my arsenal of rule manager rules for the most part, so you'd just have to modify it for you use case and exclude the door being closed as a trigger to turn off the lights.
I'm a hands on kind of girl. I'd try it. My only concern is that if you're in the garage and the lights turn off. Unless there's something else you have going on, you don't really need the variable, you could simplify it to delaying it and canceling delayed actions and save the work of trying to figure it out later when you maek changes
trigger:
g-door open
if gdoor closed
then cancel delayed actions
else if
g-door open
and lights are on
then
off lights
delay 15 minutes cancelable.
But try yours. If it works, you win! If not we'll tackle it
lower your countdown time to 1 or two minutes for testing.
@todd.barrineau - And mine is NOT better. But it's how i know how to do it. Probably nothing wrong with yours either. There's more than one way to tackle this. There's no right answer.
