Help with Tuya QT-07S Soil Moisture Sensor please (Solved)
I just purchased the Tuya QT-07S Soil Moisture Sensor and Hubitat was able to find it just fine.
I selected 'Generic Zigbee Moisture Sensor" but now I am stuck as to how to use it.
I found a post Here see the driver (it is some 1700 lines long, does that sound OK?) and am hesitating to install the driver.
Anyway, in either case, I don't know how to get numerical data from a device.
I started to make a rule, and under Trigger Events, then under device types I don't see the moisture sensor..
I am lost, so any help would be appreciated.
Thanks, Mark.
Yes, install that driver. kkossev is the master at writing Tuya Zigbee drivers for Hubitat. The worst that can happen is that it will not work and you have to switch back.
Be sure to press initialize after changing the driver. You may have to wake up the device to save advanced preferences.
Edit: Also, I think you will find it under humidity sensor, not moisture sensor, for rules.
Thanks user2574, that worked.
The device is setup, and has 3 attributes (humidity, temperature, and battery.)
I was able to trigger a rule I made to capture those attributes into hub variables.
:slight_smile:
