I would like to have a single dashboard device that I can use to set the heating setpoint of multiple physical thermostats. I want the physical thermostats to continue to work independently. I believe that the "thermostat controller app" is what I want to use. However, when I change the heating setpoint on the controlling thermostat, it does not change the heating setpoint on any of the controlled thermostats. I am attaching a screenshot of the setup.
Not 100% sure what you meant by that but Thermostat Controller, by design, does not let individual thermostats "work independently".
I would think Thermostat Scheduler would be better suited to your need. I use Thermostat Scheduler to simultaneously control setpoints on a bunch of thermostats (one of which happens to be a thermostat controller
What I would do for this is:
- Setup a Hub Variable
- Setup a Rule Machine rule:
Trigger: Hub Variable Changes
Action: Update Heating Setpoint on all those thermostats - Add the variable on the dashboard
- Enjoy!
@hubitrep @Sebastien - thank you both.
I ended up creating a virtual thermostat.
Then I created a rule that triggered when the heat setpoint of the virtual thermostat changed.
This rule has two actions. First, I set a variable to the virtual thermostat heating setpoint. Then I set the heating setpoint of my three thermostats to the variable.
Rule:
Action 1:
Action 2
Thatβs a great solution!
