Help with rule to De-ice hose
Yes, I have tried changing it to generic z wave outlet and to generic z wave plus outlet. I've also done a z wave repair after changing it. No commands go through unless it is listed as a generic z wave dimmer.
Did you click the 'configure' button after changing the driver?
I did. I changed it to generic z wave plus outlet, saved, hit configure: no response from the device. Then I changed it to generic z wave outlet, saved, hit configure, no response. Changed it back to generic z wave plus dimmer, saved, and it worked.
Strange. I wonder if the Z-wave logs show anything interesting when it fails.
If I found the correct Enbrighten unit online, it should have been supported since 2.2.7 was released in May of 2021: Release 2.2.7 Available
This thread has one more idea to try: Enbrighton Z wave plus outlet - #7 by jkudave
With credit to @rlithgow1: "on the device page switch the driver to DEVICE and click save. Click all the delete options on that page. Now switch back to generic z-wave plus outlet and click save, then click configure."
That was suggested to solve a very different problem, but maybe it will help.
I tried all that. No change.
Device Data
Device Id 65283
Device Type 65287
Firmware Version 1.0
Hardware Version 1
In Clusters 0x5E,0x26,0x70,0x85,0x8E,0x59,0x55,0x86,0x72,0x5A,0x73,0x9F,0x6C,0x7A
Manufacturer 786
Protocol Version 7.13
Serial Number 0C4314FFFEA9B2CF
Zw Node Info D3 9C 00 04 11 00 5E 26 70 85 5C 8E 59 55 86 72 5A 73 9F 6C 7A 68 23
