I need help with a Rule....maybe. This rule has been working great for months. What I have found and I'm sure it has always been this way is, If the door is closed the rule will wait 3 mins and check to see if the door is still closed. If so, lock door. Now what I just found the other day is, if door is closed and timer is set for the 3 mins and someone opens the door within the 3 min delay and closes again, The timer is NOT reset. It will lock with how many mins are left from the first delay.
How can I get the timer to reset with the second door close?
I think that would only keep the door from locking if your door is open when the 3 minute time is up. Have you tried another browser to see if the cancel option is available?
If the door opens (Changed from closed) the action is > If Door is open the Stop...do nothing.
If the door is closed (Changed from open) Delay 3mins and lock door.
Maybe I'm wrong... Lord knows I'v been wrong before on this stuff. I will test this when I get home.
