Correct chuck here is the driver code. Like I said I didn't modify this part throwing the error from the STT driver.
> * HomeSeer HS-FC200+
> * Copyright 2018 DarwinsDen.com, HomeSeer, @aruffell
> * Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
> * in compliance with the License. You may obtain a copy of the License at:
> * http://www.apache.org/licenses/LICENSE-2.0
> * Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
> * on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
> * for the specific language governing permissions and limitations under the License.
> * Author: Darwin@DarwinsDen.com, HomeSeer, @aruffell, with fan control button code leveraged from @ChadCK
> * Date: 2018-18-Oct
> * Changelog:
> * 1.0 Oct 2018 Initial Version based on WD200+
> * Button Mappings:
> * ACTION BUTTON# BUTTON ACTION
> * Double-Tap Up 1 pressed
> * Double-Tap Down 2 pressed
> * Triple-Tap Up 3 pressed
> * Triple-Tap Down 4 pressed
> * Hold Up 5 pressed
> * Hold Down 6 pressed
> * Single-Tap Up 7 pressed
> * Single-Tap Down 8 pressed
> * 4 taps up 9 pressed
> * 4 taps down 10 pressed
> * 5 taps up 11 pressed
> * 5 taps down 12 pressed
> metadata {
> definition(name: "HomeSeer FC200+ Fan Controller", namespace: "darwinsden", author: "darwin@darwinsden.com") {
> capability "Switch Level"
> capability "Actuator"
> capability "Indicator"
> capability "Switch"
> capability "Polling"
> capability "Refresh"
> capability "Sensor"
> capability "PushableButton"
> capability "Configuration"
> command "lowSpeed"
> command "medSpeed"
> command "highSpeed"
> command "tapUp2"
> command "tapDown2"
> command "tapUp3"
> command "tapDown3"
> command "tapUp4"
> command "tapDown4"
> command "tapUp5"
> command "tapDown5"
> command "holdUp"
> command "holdDown"
> command "setStatusLed", ["string","string","string"]
> command "setSwitchModeNormal"
> command "setSwitchModeStatus"
> command "setDefaultColor"
> command "setBlinkDurationMilliseconds"
> fingerprint mfr: "000C", prod: "0203", model: "0001"
> simulator {
> status "on": "command: 2003, payload: FF"
> status "off": "command: 2003, payload: 00"
> status "09%": "command: 2003, payload: 09"
> status "10%": "command: 2003, payload: 0A"
> status "33%": "command: 2003, payload: 21"
> status "66%": "command: 2003, payload: 42"
> status "99%": "command: 2003, payload: 63"
> // reply messages
> reply "2001FF,delay 5000,2602": "command: 2603, payload: FF"
> reply "200100,delay 5000,2602": "command: 2603, payload: 00"
> reply "200119,delay 5000,2602": "command: 2603, payload: 19"
> reply "200132,delay 5000,2602": "command: 2603, payload: 32"
> reply "20014B,delay 5000,2602": "command: 2603, payload: 4B"
> reply "200163,delay 5000,2602": "command: 2603, payload: 63"
> preferences {
> input "doubleTapToFullSpeed", "bool", title: "Double-Tap Up sets to full speed", defaultValue: false, displayDuringSetup: true, required: false
> input "singleTapToFullSpeed", "bool", title: "Single-Tap Up sets to full speed", defaultValue: false, displayDuringSetup: true, required: false
> input "doubleTapDownToDim", "bool", title: "Double-Tap Down sets to 25% speed", defaultValue: false, displayDuringSetup: true, required: false
> input "enable4FanSpeeds", "bool", title: "Enable 4 fan speed mode", defaultValue: false, displayDuringSetup: true, required: false
> input "reverseSwitch", "bool", title: "Reverse Switch", defaultValue: false, displayDuringSetup: true, required: false
> input "bottomled", "bool", title: "Bottom LED On if Load is Off", defaultValue: false, displayDuringSetup: true, required: false
> input("color", "enum", title: "Default LED Color", options: ["White", "Red", "Green", "Blue", "Magenta", "Yellow", "Cyan"], description: "Select Color", required: false)
> section("Fan Thresholds") {
> input "lowThreshold", "number", title: "Low Threshold", range: "1..99"
> input "medThreshold", "number", title: "Medium Threshold", range: "1..99"
> input "highThreshold", "number", title: "High Threshold", range: "1..99"
> tiles(scale: 2) {
> multiAttributeTile(name: "switch", type: "lighting", width: 6, height: 4, canChangeIcon: true) {
> tileAttribute("device.switch", key: "PRIMARY_CONTROL") {
> attributeState "on", label: '${name}', action: "switch.off", icon: "st.Home.home30", backgroundColor: "#79b821", nextState: "turningOff"
> attributeState "off", label: '${name}', action: "switch.on", icon: "st.Home.home30", backgroundColor: "#ffffff", nextState: "turningOn"
> attributeState "turningOn", label: '${name}', action: "switch.off", icon: "st.Home.home30", backgroundColor: "#79b821", nextState: "turningOff"
> attributeState "turningOff", label: '${name}', action: "switch.on", icon: "st.Home.home30", backgroundColor: "#ffffff", nextState: "turningOn"
> tileAttribute("device.level", key: "SLIDER_CONTROL") {
> attributeState "level", action: "switch level.setLevel"
> tileAttribute("device.status", key: "SECONDARY_CONTROL") {
> attributeState("default", label: '${currentValue}', unit: "")
> standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
> state "default", label: '', action: "refresh.refresh", icon: "st.secondary.configure"
> valueTile("firmwareVersion", "device.firmwareVersion", width: 2, height: 2, decoration: "flat", inactiveLabel: false) {
> state "default", label: '${currentValue}'
> valueTile("level", "device.level", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
> state "level", label: '${currentValue} %', unit: "%", backgroundColor: "#ffffff"
> standardTile("lowSpeed", "device.currentState", inactiveLabel: false, width: 2, height: 2) {
> state "default", label: 'LOW', action: "lowSpeed", icon:"st.Home.home30", backgroundColor: "#ffffff"
> state "LOW", label:'LOW', action: "lowSpeed", icon:"st.Home.home30", backgroundColor: "#79b821"
> state "ADJUSTING.LOW", label:'LOW', action: "lowSpeed", icon:"st.Home.home30", backgroundColor: "#2179b8"
> standardTile("medSpeed", "device.currentState", inactiveLabel: false, width: 2, height: 2) {
> state "default", label: 'MED', action: "medSpeed", icon:"st.Home.home30", backgroundColor: "#ffffff"
> state "MED", label: 'MED', action: "medSpeed", icon:"st.Home.home30", backgroundColor: "#79b821"
> state "ADJUSTING.MED", label:'MED', action: "medSpeed", icon:"st.Home.home30", backgroundColor: "#2179b8"
> standardTile("highSpeed", "device.currentState", inactiveLabel: false, width: 2, height: 2) {
> state "default", label: 'HIGH', action: "highSpeed", icon:"st.Home.home30", backgroundColor: "#ffffff"
> state "HIGH", label: 'HIGH', action: "highSpeed", icon:"st.Home.home30", backgroundColor: "#79b821"
> state "ADJUSTING.HIGH", label:'HIGH', action: "highSpeed", icon:"st.Home.home30", backgroundColor: "#2179b8"
> valueTile("tapUp2", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 1\nTap\n▲▲", backgroundColor: "#ffffff", action: "tapUp2"
> valueTile("tapDown2", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 2\nTap\n▼▼", backgroundColor: "#ffffff", action: "tapDown2"
> valueTile("tapUp3", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 3\nTap\n▲▲▲", backgroundColor: "#ffffff", action: "tapUp3"
> valueTile("tapDown3", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 4\nTap\n▼▼▼", backgroundColor: "#ffffff", action: "tapDown3"
> valueTile("tapUp1", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 7\nTap\n▲", backgroundColor: "#ffffff", action: "tapUp1"
> valueTile("tapDown1", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 8\nTap\n▼", backgroundColor: "#ffffff", action: "tapDown1"
> valueTile("tapUp4", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 9\nTap\n▲▲▲▲", backgroundColor: "#ffffff", action: "tapUp4"
> valueTile("tapDown4", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 10\nTap\n▼▼▼▼", backgroundColor: "#ffffff", action: "tapDown4"
> valueTile("tapUp5", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 11\nTap\n▲▲▲▲▲", backgroundColor: "#ffffff", action: "tapUp5"
> valueTile("tapDown5", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 12\nTap\n▼▼▼▼▼", backgroundColor: "#ffffff", action: "tapDown5"
> valueTile("holdUp", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 5\nHold\n▲", backgroundColor: "#ffffff", action: "holdUp"
> valueTile("holdDown", "device.button", width: 1, height: 1, decoration: "flat") {
> state "default", label: "Button 6\nHold\n▼", backgroundColor: "#ffffff", action: "holdDown"
> main(["switch"])
> details(["switch", "lowSpeed", "medSpeed", "highSpeed", "tapUp2", "tapDown2", "tapUp3", "tapDown3", "holdUp", "holdDown", "tapUp1", "tapDown1", "tapUp4", "tapDown4", "tapUp5", "tapDown5", "level", "firmwareVersion", "refresh"])
> def parse(String description) {
> def result = null
> log.debug(description)
> if (description != "updated") {
> def cmd = zwave.parse(description, [0x20: 1, 0x26: 1, 0x70: 1])
> if (cmd) {
> result = zwaveEvent(cmd)
> if (!result) {
> log.debug "Parse returned ${result} for command ${cmd}"
> } else {
> log.debug "Parse returned ${result}"
> return result
> def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
> dimmerEvents(cmd)
> def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
> dimmerEvents(cmd)
> def zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
> dimmerEvents(cmd)
> def zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelSet cmd) {
> dimmerEvents(cmd)
> private dimmerEvents(hubitat.zwave.Command cmd) {
> def lowThresholdvalue = (settings.lowThreshold != null && settings.lowThreshold != "") ? settings.lowThreshold.toInteger() : 33
> def medThresholdvalue = (settings.medThreshold != null && settings.medThreshold != "") ? settings.medThreshold.toInteger() : 66
> def highThresholdvalue = (settings.highThreshold != null && settings.highThreshold != "") ? settings.highThreshold.toInteger() : 99
> def value = (cmd.value ? "on" : "off")
> def result = [createEvent(name: "switch", value: value)]
> state.lastLevel = cmd.value
> if (cmd.value && cmd.value <= 100) {
> if (cmd.value > 0 && cmd.value <= lowThresholdvalue) { sendEvent(name: "currentState", value: "LOW" as String) }
> if (cmd.value >= lowThresholdvalue+1 && cmd.value <= medThresholdvalue) { sendEvent(name: "currentState", value: "MED" as String) }
> if (cmd.value >= medThresholdvalue+1) { sendEvent(name: "currentState", value: "HIGH" as String) }
> result << createEvent(name: "level", value: cmd.value, unit: "%")
> return result
> def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
> log.debug "ConfigurationReport $cmd"
> def value = "when off"
> if (cmd.configurationValue[0] == 1) {
> value = "when on"
> if (cmd.configurationValue[0] == 2) {
> value = "never"
> createEvent([name: "indicatorStatus", value: value])
> def zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
> createEvent([name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false])
> def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
> log.debug "manufacturerId: ${cmd.manufacturerId}"
> log.debug "manufacturerName: ${cmd.manufacturerName}"
> state.manufacturer = cmd.manufacturerName
> log.debug "productId: ${cmd.productId}"
> log.debug "productTypeId: ${cmd.productTypeId}"
> def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
> updateDataValue("MSR", msr)
> setFirmwareVersion()
> createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
> def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
> //updateDataValue(“applicationVersion”, "${cmd.applicationVersion}")
> log.debug("received Version Report")
> log.debug "applicationVersion: ${cmd.applicationVersion}"
> log.debug "applicationSubVersion: ${cmd.applicationSubVersion}"
> state.firmwareVersion = cmd.applicationVersion + '.' + cmd.applicationSubVersion
> log.debug "zWaveLibraryType: ${cmd.zWaveLibraryType}"
> log.debug "zWaveProtocolVersion: ${cmd.zWaveProtocolVersion}"
> log.debug "zWaveProtocolSubVersion: ${cmd.zWaveProtocolSubVersion}"
> createEvent([descriptionText: "Firmware V" + state.firmwareVersion, isStateChange: false])
> def zwaveEvent(hubitat.zwave.commands.firmwareupdatemdv2.FirmwareMdReport cmd) {
> log.debug("received Firmware Report")
> log.debug "checksum: ${cmd.checksum}"
> log.debug "firmwareId: ${cmd.firmwareId}"
> log.debug "manufacturerId: ${cmd.manufacturerId}" [: ]
> def zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
> [createEvent(name: "switch", value: "on"), response(zwave.switchMultilevelV1.switchMultilevelGet().format())]
> def zwaveEvent(hubitat.zwave.Command cmd) {
> // Handles all Z-Wave commands we aren’t interested in
> def on() {
> sendEvent(tapUp1Response("digital"))
> delayBetween([
> zwave.basicV1.basicSet(value: 0xFF).format(),
> ], 5000)
> def off() {
> sendEvent(tapDown1Response("digital"))
> delayBetween([
> zwave.basicV1.basicSet(value: 0x00).format(),
> ], 5000)
> def setLevel(value) {
> log.debug "setLevel >> value: $value"
> if (value == "LOW") { value = lowThresholdvalue }
> if (value == "MED") { value = medThresholdvalue }
> if (value == "HIGH") { value = highThresholdvalue }
> def valueaux = value as Integer
> def level = Math.max(Math.min(valueaux, 99), 0)
> if (level > 0) {
> sendEvent(name: "switch", value: "on")
> } else {
> sendEvent(name: "switch", value: "off")
> if (level <= lowThresholdvalue) { sendEvent(name: "currentState", value: "ADJUSTING.LOW" as String, displayed: false) }
> if (level >= lowThresholdvalue+1 && level <= medThresholdvalue) { sendEvent(name: "currentState", value: "ADJUSTING.MED" as String, displayed: false) }
> if (level >= medThresholdvalue+1) { sendEvent(name: "currentState", value: "ADJUSTING.HIGH" as String, displayed: false) }
> sendEvent(name: "level", value: level, unit: "%")
> def result = []
> result += response(zwave.basicV1.basicSet(value: level))
> result += response("delay 5000")
> result += response(zwave.switchMultilevelV1.switchMultilevelGet())
> def lowSpeed() {
> setLevel("LOW")
> def medSpeed() {
> setLevel("MED")
> def highSpeed() {
> setLevel("HIGH")
> * Set dimmer to status mode, then set the color of the individual LED
> * led = 1-7
> * color = 0=0ff
> * 1=red
> * 2=green
> * 3=blue
> * 4=magenta
> * 5=yellow
> * 6=cyan
> * 7=white
> def setBlinkDurationMilliseconds(newBlinkDuration) {
> def cmds = []
> if (0 < newBlinkDuration && newBlinkDuration < 25500) {
> log.debug "setting blink duration to: ${newBlinkDuration} ms"
> state.blinkDuration = newBlinkDuration.toInteger() / 100
> log.debug "blink duration config parameter 30 is: ${state.blinkDuration}"
> cmds << zwave.configurationV2.configurationSet(configurationValue: [state.blinkDuration.toInteger()], parameterNumber: 30, size: 1).format()
> } else {
> log.debug "commanded blink duration ${newBlinkDuration} is outside range 0 … 25500 ms"
> return cmds
> def setStatusLed(led, color, blink) {
> def cmds = []
> if (state.statusled1 == null) {
> state.statusled1 = 0
> state.statusled2 = 0
> state.statusled3 = 0
> state.statusled4 = 0
> state.blinkval = 0
> /* set led # and color */
> switch (led) {
> case 1:
> state.statusled1 = color
> break
> case 2:
> state.statusled2 = color
> break
> case 3:
> state.statusled3 = color
> break
> case 4:
> state.statusled4 = color
> break
> case 0:
> case 5:
> // Special case - all LED's
> break
> if (state.statusled1 == 0 && state.statusled2 == 0 && state.statusled3 == 0 && state.statusled4 == 0 && state.statusled5 == 0 && state.statusled6 == 0 && state.statusled7 == 0) {
> // no LEDS are set, put back to NORMAL mode
> cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 13, size: 1).format()
> } else {
> // at least one LED is set, put to status mode
> cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 13, size: 1).format()
> if (led == 5 | led == 0) {
> for (def ledToChange = 1; ledToChange <= 4; ledToChange++) {
> // set color for all LEDs
> cmds << zwave.configurationV2.configurationSet(configurationValue: [color], parameterNumber: ledToChange + 20, size: 1).format()
> } else {
> // set color for specified LED
> cmds << zwave.configurationV2.configurationSet(configurationValue: [color], parameterNumber: led + 20, size: 1).format()
> // check if LED should be blinking
> def blinkval = state.blinkval
> if (blink) {
> switch (led) {
> case 1:
> blinkval = blinkval | 0x1
> break
> case 2:
> blinkval = blinkval | 0x2
> break
> case 3:
> blinkval = blinkval | 0x4
> break
> case 4:
> blinkval = blinkval | 0x8
> break
> case 0:
> case 5:
> blinkval = 0x7F
> break
> cmds << zwave.configurationV2.configurationSet(configurationValue: [blinkval], parameterNumber: 31, size: 1).format()
> state.blinkval = blinkval
> // set blink frequency if not already set, 5=500ms
> if (state.blinkDuration == null | state.blinkDuration < 0 | state.blinkDuration > 255) {
> cmds << zwave.configurationV2.configurationSet(configurationValue: [5], parameterNumber: 30, size: 1).format()
> } else {
> switch (led) {
> case 1:
> blinkval = blinkval & 0xFE
> break
> case 2:
> blinkval = blinkval & 0xFD
> break
> case 3:
> blinkval = blinkval & 0xFB
> break
> case 4:
> blinkval = blinkval & 0xF7
> break
> case 0:
> case 5:
> blinkval = 0
> break
> delayBetween(cmds, 150)
> * Set Dimmer to Status mode (exit normal mode)
> def setSwitchModeNormal() {
> def cmds = []
> delayBetween(cmds, 500)
> * Set the color of the LEDS for normal dimming mode, shows the current dim level
> def setSwitchModeStatus() {
> def cmds = []
> * Set the color of the LEDS for normal fan speed mode, shows the current speed
> def setDefaultColor(color) {
> def cmds = []
> cmds << zwave.configurationV2.configurationSet(configurationValue: [color], parameterNumber: 14, size: 1).format()
> def poll() {
> def refresh() {
> log.debug "refresh() called"
> configure()
> def zwaveEvent(hubitat.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
> log.debug("sceneNumber: ${cmd.sceneNumber} keyAttributes: ${cmd.keyAttributes}")
> def result = []
> switch (cmd.sceneNumber) {
> case 1:
> // Up
> switch (cmd.keyAttributes) {
> case 0:
> // Press Once
> result += createEvent(tapUp1Response("physical"))
> result += createEvent([name: "switch", value: "on", type: "physical"])
> if (singleTapToFullSpeed) {
> result += setLevel(99)
> break
> case 1:
> result = createEvent([name: "switch", value: "on", type: "physical"])
> break
> case 2:
> // Hold
> result += createEvent(holdUpResponse("physical"))
> break
> case 3:
> // 2 Times
> result += createEvent(tapUp2Response("physical"))
> if (doubleTapToFullSpeed) {
> break
> case 4:
> // 3 times
> result = createEvent(tapUp3Response("physical"))
> break
> case 5:
> // 4 times
> result = createEvent(tapUp4Response("physical"))
> break
> case 6:
> // 5 times
> result = createEvent(tapUp5Response("physical"))
> break
> default:
> log.debug("unexpected up press keyAttribute: $cmd.keyAttributes")
> break
> case 2:
> // Down
> case 0:
> // Press Once
> result += createEvent(tapDown1Response("physical"))
> result += createEvent([name: "switch", value: "off", type: "physical"])
> break
> case 1:
> result = createEvent([name: "switch", value: "off", type: "physical"])
> break
> case 2:
> // Hold
> result += createEvent(holdDownResponse("physical"))
> break
> case 3:
> // 2 Times
> result += createEvent(tapDown2Response("physical"))
> if (doubleTapDownToDim) {
> result += setLevel(25)
> break
> case 4:
> // 3 Times
> result = createEvent(tapDown3Response("physical"))
> break
> case 5:
> // 4 Times
> result = createEvent(tapDown4Response("physical"))
> break
> case 6:
> // 5 Times
> result = createEvent(tapDown5Response("physical"))
> break
> default:
> log.debug("unexpected down press keyAttribute: $cmd.keyAttributes")
> break
> default:
> // unexpected case
> log.debug("unexpected scene: $cmd.sceneNumber")
> return result
> def tapUp1Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▲")
> [name: "button", value: "pushed", data: [buttonNumber: "7"], descriptionText: "$device.displayName Tap-Up-1 (button 7) pressed",
> isStateChange: true, type: "$buttonType"]
> def tapDown1Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▼")
> [name: "button", value: "pushed", data: [buttonNumber: "8"], descriptionText: "$device.displayName Tap-Down-1 (button 8) pressed",
> def tapUp2Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▲▲")
> [name: "button", value: "pushed", data: [buttonNumber: "1"], descriptionText: "$device.displayName Tap-Up-2 (button 1) pressed",
> def tapDown2Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▼▼")
> [name: "button", value: "pushed", data: [buttonNumber: "2"], descriptionText: "$device.displayName Tap-Down-2 (button 2) pressed",
> def tapUp3Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▲▲▲")
> [name: "button", value: "pushed", data: [buttonNumber: "3"], descriptionText: "$device.displayName Tap-Up-3 (button 3) pressed",
> def tapUp4Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▲▲▲▲")
> [name: "button", value: "pushed", data: [buttonNumber: "9"], descriptionText: "$device.displayName Tap-Up-4 (button 9) pressed",
> def tapUp5Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▲▲▲▲▲")
> [name: "button", value: "pushed", data: [buttonNumber: "11"], descriptionText: "$device.displayName Tap-Up-5 (button 11) pressed",
> def tapDown3Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▼▼▼")
> [name: "button", value: "pushed", data: [buttonNumber: "4"], descriptionText: "$device.displayName Tap-Down-3 (button 4) pressed",
> def tapDown4Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▼▼▼▼")
> [name: "button", value: "pushed", data: [buttonNumber: "10"], descriptionText: "$device.displayName Tap-Down-3 (button 10) pressed",
> def tapDown5Response(String buttonType) {
> sendEvent(name: "status", value: "Tap ▼▼▼▼▼")
> [name: "button", value: "pushed", data: [buttonNumber: "12"], descriptionText: "$device.displayName Tap-Down-3 (button 12) pressed",
> def holdUpResponse(String buttonType) {
> sendEvent(name: "status", value: "Hold ▲")
> [name: "button", value: "pushed", data: [buttonNumber: "5"], descriptionText: "$device.displayName Hold-Up (button 5) pressed",
> def holdDownResponse(String buttonType) {
> sendEvent(name: "status", value: "Hold ▼")
> [name: "button", value: "pushed", data: [buttonNumber: "6"], descriptionText: "$device.displayName Hold-Down (button 6) pressed",
> def tapUp1() {
> def tapDown1() {
> def tapUp2() {
> sendEvent(tapUp2Response("digital"))
> def tapDown2() {
> sendEvent(tapDown2Response("digital"))
> def tapUp3() {
> sendEvent(tapUp3Response("digital"))
> def tapDown3() {
> sendEvent(tapDown3Response("digital"))
> def tapUp4() {
> sendEvent(tapUp4Response("digital"))
> def tapDown4() {
> sendEvent(tapDown4Response("digital"))
> def tapUp5() {
> sendEvent(tapUp5Response("digital"))
> def tapDown5() {
> sendEvent(tapDown5Response("digital"))
> def holdUp() {
> sendEvent(holdUpResponse("digital"))
> def holdDown() {
> sendEvent(holdDownResponse("digital"))
> def setFirmwareVersion() {
> def versionInfo = ''
> if (state.manufacturer) {
> versionInfo = state.manufacturer + ' '
> if (state.firmwareVersion) {
> versionInfo = versionInfo + "Firmware V" + state.firmwareVersion
> } else {
> versionInfo = versionInfo + "Firmware unknown"
> sendEvent(name: "firmwareVersion", value: versionInfo, isStateChange: true, displayed: false)
> def configure() {
> log.debug("configure() called")
> sendEvent(name: "numberOfButtons", value: 12, displayed: false)
> def commands = []
> commands << setPrefs()
> commands << zwave.switchMultilevelV1.switchMultilevelGet().format()
> commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
> commands << zwave.versionV1.versionGet().format()
> delayBetween(commands, 500)
> def setPrefs() {
> log.debug("set prefs")
> def cmds = []
> if (color) {
> switch (color) {
> case "White":
> cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 14, size: 1).format()
> break
> case "Red":
> cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 14, size: 1).format()
> break
> case "Green":
> cmds << zwave.configurationV2.configurationSet(configurationValue: [2], parameterNumber: 14, size: 1).format()
> break
> case "Blue":
> cmds << zwave.configurationV2.configurationSet(configurationValue: [3], parameterNumber: 14, size: 1).format()
> break
> case "Magenta":
> cmds << zwave.configurationV2.configurationSet(configurationValue: [4], parameterNumber: 14, size: 1).format()
> break
> case "Yellow":
> cmds << zwave.configurationV2.configurationSet(configurationValue: [5], parameterNumber: 14, size: 1).format()
> break
> case "Cyan":
> cmds << zwave.configurationV2.configurationSet(configurationValue: [6], parameterNumber: 14, size: 1).format()
> break
> if (reverseSwitch) {
> cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
> } else {
> cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 4, size: 1).format()
> if (bottomled) {
> cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 3, size: 1).format()
> } else {
> cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()
> //Sets fan type
> if (enable4FanSpeeds) {
> //3 Speeds
> cmds << zwave.configurationV2.configurationSet(configurationValue: [1], parameterNumber: 5, size: 1).format()
> } else {
> //4 Speeds
> cmds << zwave.configurationV2.configurationSet(configurationValue: [0], parameterNumber: 5, size: 1).format()
> //Enable the following configuration gets to verify configuration in the logs
> //cmds << zwave.configurationV1.configurationGet(parameterNumber: 5).format()
> //cmds << zwave.configurationV1.configurationGet(parameterNumber: 7).format()
> //cmds << zwave.configurationV1.configurationGet(parameterNumber: 8).format()
> //cmds << zwave.configurationV1.configurationGet(parameterNumber: 9).format()
> //cmds << zwave.configurationV1.configurationGet(parameterNumber: 10).format()
> return cmds
> def updated() {
> def cmds = []
> cmds << setPrefs
