I am trying to create an http button that supports hue scenes and transition times. My code throws no errors, but it doesn't turn my lights on either. How do I capture the return json from the hue API and then log the return so I can see what HE is receiving?
Here is my code:
* Hue HTTP Momentary Switch
* Copyright 2018 Daniel Ogorchock
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Change History:
* Date Who What
* 2018-02-18 Dan Ogorchock Original Creation
* 2019-11-01 Joe Rosiak Modified to support Hue Scenes
metadata {
definition (name: "Hue HTTP Momentary Switch", namespace: "Keo", author: "Joe Rosiak") {
capability "Switch"
capability "Momentary"
capability "Switch Level"
preferences {
input(name: "hueWhiteListUser", type: "sting", title: "Hue Whitelist User", required: true, displayDuringSetup: true)
input(name: "deviceIP", type: "string", title:"Device IP Address", description: "Enter IP Address of your HTTP server", required: true, displayDuringSetup: true)
input(name: "devicePort", type: "string", title:"Device Port", description: "Enter Port of your HTTP server (defaults to 80)", defaultValue: "80", required: false, displayDuringSetup: true)
//input(name: "devicePath", type: "string", title:"URL Path", description: "Rest of the URL, include forward slash.", displayDuringSetup: true)
input(name: "deviceMethod", type: "enum", title: "POST, GET, or PUT", options: ["POST","GET","PUT"], defaultValue: "POST", required: true, displayDuringSetup: true)
input(name: "hueGroupID", type: "string", title: "Hue Group ID", required: true, displayDuringSetup: true)
input(name: "hueSceneID", type: "string", title: "Hue Scene ID", required: true, displayDuringSetup: true)
input(name: "hueSceneTTime", type: "int", title: "Hue Scene Transition time", required: true, displayDuringSetup: true)
log.debug(description)
def push() {
//toggle the switch to generate events for anything that is subscribed
sendEvent(name: "switch", value: "on", isStateChange: true)
runIn(1, toggleOff)
//sendEvent(name: "switch", value: "off", isStateChange: true)
runCmd(devicePath, deviceMethod)
def toggleOff() {
def on() {
push()
def off() {
push()
def setheattemp() {
def path = "/setheat?" + "somevar"
//Add logic to controll heat
def setfanspeed() {
def path = "/setfanspeed?" + "somevar"
//Add logic to control the fan speed
def toggleoscillation() {
def path = "/oscillation?" + "somevar"
//Add logic to toggle oscillation
def runCmd(String varCommand, String method) {
def localDevicePort = (devicePort==null) ? "80" : devicePort
def path = varCommand
def body = "{ 'scene': '${hueSceneID}', 'transitiontime': '${hueSceneTTime}'}"
def headers = [:]
headers.put("HOST", "${deviceIP}/api/${hueWhiteListUser}/groups/${hueGroupID}/action")
//:${localDevicePort}")
headers.put("Content-Type", "application/x-www-form-urlencoded")
try {
def hubAction = new hubitat.device.HubAction(
method: method,
path: path,
body: body,
headers: headers
log.debug hubAction
return hubAction
catch (Exception e) {
log.debug "runCmd hit exception ${e} on ${hubAction}"
