Hello,
I'm a Iris shutdown refugee and I'm working on getting my Hubitat set up as a security system (initially). I had a couple questions I could use some clarification from other ex-Iris users or in general.
When using the Iris Keypad IL02_1. I have no problem setting up "Armed Away" using the keypad's ON button and "Armed Home" using the PARTIAL button. However I tried changing the "Use Partial Button to Arm Night" option and if I have anything setup in the "Armed Night" section the keypad will not Arm to Away... only to Night. Any ideas?
When I disarm using the keypad from any mode, I get several seconds of beeping out of the keypad afterwards. Any ideas on could be causing it? It's not crucial, just annoying.
Is it possible to setup the system to determine whether to arm as Away or Home based on whether there is a change in a contact "door" sensor. Similar to how a normal security system would do?
I have a generic zigbee plug in outlet that I'm using to trigger a hardwired non-smart siren. I have figured out how to setup to turn this outlet on in the Lights Alerts settings. But what I want to know is if there is a way to shut off this outlet once the system has been disarmed.
I appreciate any help... thanks, Robert
