I bought several MCOHome 610 series switches and Lumi Z wave switches, most of the lumis control 2 light sources and one roller (up - down buttons), the problem is I can't find an appropriate fully compatible driver to any of them.
Firstly, I tried the Generic z wave plus Multiswitch on the Lumi, but it won't generate the roller buttons, so I cant control them.
I tried using the MCO community drivers on the Lumi, when I press "off" the roller raise up and when I press "on" it lowers down, but I cant stop the motion.
Furthermore, the MCO switches with the community driver set, will always update the status in the Hubitat system in 2 sec delay after pressing.
When I try the Generic z wave plus Multiswitch driver, it wont update at all after pressing, but they respond to the Hub perfectly.
More over, the Mco updates the Hubitat instantly when I set them as z wave plus buttons combined with rule machine to check a press, but the switch wont respond to the hub or update his self status.
It will really help me if someone knows about fitting driver or if someone can modify one to fit those switches.
thank you in advance!!
The MCO driver:"
MCO Touch Panel Power Single/Double/Triple Switch (Driver for Triple ) You will also need to import this
did you install the "child" driver? Looks like 2 drivers are needed, then unpair the device and reconnect after adding both drivers, should lead to the hub finding multiple devices for that one single physical device.
yes, I got the three childes separate control and using the third child I could move the roller up or down but it didn't stop moving
just to clarify I used this driver on the Lumi and it worked as mentioned
I just looked and the Lumi are really neat switches. Anyway, check if touches on the roller control switch is producing "pushed, held, released" events in the device events. If you see those events, you can create a rule 5.1 to control the movement of the shades.
