Hello all
I have added two new door sensors to my house (front and lanai) with the following use case:
- If someone opens either door and leaves it open for three minutes, then the thermostat will turn off.
- If someone has opened the door and closes it in less than three minutes, then nothing should happen.
- If the door closes, then it should re-run the appropriate rule to set the thermostat based upon the current mode.
I would like to see if I could get help making is smarter and simpler, as I don't feel as though I have grasped all of the potential use cases:
