I created a basic rule for my Schlage Connect zwave deadbolt to unlock as my iPhone becomes present. However, it's not unlocking my deadbolt. Prior to swapping to Hubitat, I was running the same automation with ST successfully.. Can you guys tell me what I may be doing wrong? Forgive my ignorance.. I've only been using Hubitat for a couple of weeks.
Post what you have so far for the rule. Also, I assume you've verified the presence sensor is changing correctly? Just a warning, I've had my presence sensor change to away and back a few times while we were at home so it may unlock unexpectedly if that happens if you get the rule working.
You are better off using multiple presence sensors on the combined presence sensor app. I use my phone and a fob to ensure triggering. (My phone usually has enough time to come out of sleep to help trip)
