Help with AWAY rule
I tried this yesterday, and got it to work by sending me a text, but that was then, and I cant seem to get this to work...
I had it set up way more complex than this, but have since dummed it down to see if I could get it to work, and so far I have not.
Can anyone shed any light on what I am doing wrong?
You can see its set in AWAY mode, and right now the door is closed (false). when I open the door and it turns to (true) I do not get the text nor does the light flash.
Could you at the Logs page, and/or the app events from the app status page, and see what the rule is logging?
Aha! Seems like it may be a hubitat issue!
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 09:10:14.319 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (allHandler)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 09:10:14.253 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:24:58.431 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms is now False
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:24:21.886 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms is now False
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:24:21.820 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact closed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:24:15.766 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (allHandler)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:24:15.718 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:23:56.420 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Resumed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:23:54.120 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Paused
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:23:42.613 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms is now False
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:23:42.573 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact closed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:23:33.556 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (allHandler)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:23:33.504 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:23:23.349 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms is now False
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:23:23.302 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact closed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:22:55.405 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (updated)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:20:11.913 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (allHandler)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:20:11.849 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:19:39.985 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms is now False
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:12:25.393 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms is now False
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:12:25.342 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact closed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:11:40.644 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (allHandler)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:11:40.580 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:11:29.401 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms is now False
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:10:08.555 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (allHandler)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:10:08.494 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door Lock lock unlocked
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:09:36.686 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms is now False
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:06:52.068 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door Lock lock locked
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:06:50.624 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact closed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:06:34.288 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:06:33.118 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door Lock lock unlocked
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:05:40.848 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (updated)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:05:28.594 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:05:03.180 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Living Room Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:04:54.550 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:04:33.313 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door Lock lock locked
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:04:31.918 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact closed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:04:27.706 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:04:24.966 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact closed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:03:56.636 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:03:42.881 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Living Room Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:03:32.303 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact closed
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:03:28.047 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Front Door contact open
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:03:03.131 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Living Room Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 08:02:55.413 pm [error](http://192.168.1.17/installedapp/configure/82)java.lang.IllegalArgumentException: Command 'flash' is not supported by device. (updated)
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 07:13:19.019 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 07:12:44.719 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 07:01:00.027 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 06:59:46.502 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 06:58:44.651 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 06:57:23.182 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 06:38:13.672 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 06:37:03.397 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 06:28:30.520 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 06:27:30.873 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 05:20:25.163 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 05:19:44.896 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion active
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 05:16:15.430 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion inactive
[app:82](http://192.168.1.17/logs/past#app82)2018-12-12 05:15:36.594 pm [info](http://192.168.1.17/installedapp/configure/82)Away Alarms: Upstairs Hallway Motion motion active
Im also getting this error.. and my phone number is set properly
app:822018-12-12 09:18:37.962 pm errorjava.lang.Exception: Invalid phone number, numbers must start with + and be followed by country code and phone number (allHandler)
You got it to send you a text before, but did you have flash light in the rule at the time that you tested it? It’s saying that your lights don’t support it the log. Are these lights connected directly to the hub, and if so when you look in the driver is there a flash button? If there isn’t then flash is not supported so you can’t use that. You’ll have to simulate flash with another rule that turns the lights off and then on with a periodic schedule in seconds when that rule becomes true and stop actions when that ā€œflashā€ rule becomes false.
The light feature wasnt in there when I got it to work the first time. however it was removed and the second error i got popped up.
To see if they are related, try deleting the rule and recreating it with just the text messages. Ensuring that you number is entered as +1[area code][phonenumber] (e.g. +15556667777).
Keeping in mind that SMS is limited to 10 per day.
Using HSM, things are working for the notifications..
As for the "flash" feature, I was using a rule before to accomplish alarms, but now after enabling the HSM, the flash feature is still getting the same error
app:942018-12-13 11:40:23.744 errorjava.lang.IllegalArgumentException: Command 'flash' is not supported by device. (intrusionHandlerAway)
