Hello, i cant seem to get my head around this rule.
when HSM is in Arm away mode if the front door contact is open ( as in you are coming home) i want the Piezo buzzer to beep two time, just to let you know the system is armed and has to be turned off.
so i have these 3 elements but i cant seem to get the rule correct for it to work.
HSM ARM AWAY
BEEP SWITCH ( PIEZO BUZZER)
DOOR CONTACT
Thanks for any help.
Sean
