[{"id":"1f36ecdd.e941e3","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"b92554d8.177de8","type":"switch","z":"1f36ecdd.e941e3","name":"is Locked","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"Locked","vt":"str"},{"t":"neq","v":"Locked","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":380,"y":140,"wires":[["35b46728.1963a8"],["ee7201e7.dbb8e"]]},{"id":"35b46728.1963a8","type":"change","z":"1f36ecdd.e941e3","name":"set True","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":180,"wires":[["a878ebdf.97ce08"]]},{"id":"585889aa.3b9fa8","type":"hubitat device","z":"1f36ecdd.e941e3","name":"Garage Lock","server":"f17566a9.c052b8","deviceId":"","attribute":"","sendEvent":true,"x":160,"y":140,"wires":[["b92554d8.177de8"]]},{"id":"1f8062e5.b9f4ad","type":"hubitat command","z":"1f36ecdd.e941e3","name":"Unlock Foyer Lock","server":"f17566a9.c052b8","deviceId":"","command":"","commandArgs":"","x":1330,"y":400,"wires":[]},{"id":"a878ebdf.97ce08","type":"BooleanLogicUltimate","z":"1f36ecdd.e941e3","name":"","filtertrue":"both","persist":true,"sInitializeWith":"false","triggertopic":"trigger","outputtriggeredby":"all","inputCount":"4","topic":"result","x":820,"y":240,"wires":[["d1146cc7.5f41c"],,]},{"id":"38ccad1f.303332","type":"hubitat device","z":"1f36ecdd.e941e3","name":"Overhead Door","server":"f17566a9.c052b8","deviceId":"","attribute":"","sendEvent":true,"x":160,"y":200,"wires":[["fddb93b0.4cf1b"]]},{"id":"ed43e2fc.0294f","type":"hubitat device","z":"1f36ecdd.e941e3","name":"Front Door","server":"f17566a9.c052b8","deviceId":"","attribute":"","sendEvent":true,"x":150,"y":260,"wires":[["fddb93b0.4cf1b"]]},{"id":"9083cc8a.894f5","type":"hubitat device","z":"1f36ecdd.e941e3","name":"Override switch","server":"f17566a9.c052b8","deviceId":"","attribute":"","sendEvent":true,"x":160,"y":320,"wires":[["ce5bbbbf.cad058"]]},{"id":"aa8d41ae.f014f","type":"hubitat device","z":"1f36ecdd.e941e3","name":"Foyer Lock","server":"f17566a9.c052b8","deviceId":"","attribute":"","sendEvent":false,"x":1130,"y":240,"wires":[["5adbe11b.e0516"]]},{"id":"4d5bc2ef.5d49fc","type":"hubitat device","z":"1f36ecdd.e941e3","name":"Foyer Lock","server":"f17566a9.c052b8","deviceId":"","attribute":"","sendEvent":false,"x":1090,"y":400,"wires":[["e857ffbb.5b92b"]]},{"id":"68a5251f.7f061c","type":"hubitat command","z":"1f36ecdd.e941e3","name":"Lock Foyer Lock","server":"f17566a9.c052b8","deviceId":"","command":"","commandArgs":"","x":1320,"y":240,"wires":[]},{"id":"fddb93b0.4cf1b","type":"switch","z":"1f36ecdd.e941e3","name":"is Closed","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"closed","vt":"str"},{"t":"neq","v":"closed","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":380,"y":240,"wires":[["35b46728.1963a8"],["ee7201e7.dbb8e"]]},{"id":"ce5bbbbf.cad058","type":"switch","z":"1f36ecdd.e941e3","name":"is On","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"neq","v":"on","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":320,"wires":[["35b46728.1963a8"],["ee7201e7.dbb8e"]]},{"id":"ee7201e7.dbb8e","type":"change","z":"1f36ecdd.e941e3","name":"set False","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":260,"wires":[["a878ebdf.97ce08"]]},{"id":"5adbe11b.e0516","type":"switch","z":"1f36ecdd.e941e3","name":"not locked","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"Locked","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1240,"y":320,"wires":[["68a5251f.7f061c"]]},{"id":"e857ffbb.5b92b","type":"switch","z":"1f36ecdd.e941e3","name":"locked?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"locked","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1250,"y":480,"wires":[["1f8062e5.b9f4ad"]]},{"id":"d1146cc7.5f41c","type":"switch","z":"1f36ecdd.e941e3","name":"is True","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":940,"y":360,"wires":[["aa8d41ae.f014f"],["4d5bc2ef.5d49fc"]]},{"id":"f17566a9.c052b8","type":"hubitat config","z":"","name":"","usetls":false,"host":"192.168.2.3","port":"80","appId":"3424","nodeRedServer":"http://192.168.2.9:1880","webhookPath":"/hubitat/webhook","autoRefresh":true}]
