In RM, I have a trigger, and when that trigger occurs, I want an action to run 10 times, with the same interval between each. Is this not possible or am I just not figuring it out or am I not understanding the HE language?
I initial copied and pasted my action 9 more times and just put a delay on each, but this means if I need to edit the action, I have to edit 10 lines. I would like to use the HE repeat function to make editing the action more efficient.
However, when I select repeat, all I get is "Repeat n times every x minutes."
I want a rule that says Repeat once every x minutes, for a total of n times, then stop.
How do I do this? Or does the "Repeat n times every x minutes" with an "END-REP" after it a poorly worded version of exactly what I am trying to accomplish?
