Hi, I would definitly need some help. I have a box enclosure with 4 Eaton switches RF9601-DW-Z. Each one activates a 110V coil Contactor. I want to control 2 pumps (Pool and SPA) and their respective heaters. The switches behavior is crazy. Even without load, often, when I turn off one switch, other may funnyly trip and also turn off. Not all the time and not allways the same switches. I tried the Eaton Driver, the Generic and Generic+ Switch Driver and it is allways the same. The same thing sometimes happen when I manually close one of those switches. Those swithes are influenced by each other. Crazy
-Are the Eaton switch Crap?
-Are the switches suffering from interférences?
-Switches are installed by pairs into a cabinet. Closed or open cabinet...no difference.
Please help.
