I recently picked up the Doorbell 6 because I wanted to be able to mute the doorbell at certain times. I've been able to activate it with my Inovelli switches but I haven't figured out how to make a dashboard button to activate it. Can someone give me a jump start please?
(Bonus points if you can tell me why the siren is flashing constantly and how to stop it )
This is usually a battery problem with the button. Take the button down, take the back cover off. Make sure the battery is seated correctly and then make sure you crew the cover on tightly to keep water out.
You want to create a virtual button device with 1 button and put that on your dashboard. Then you want to create a RM rule that when the button is pressed you mute the doorbell. You can find the mute command under custom actions for the doorbell.
Awesome! Thanks for the direction. I'll post back if I run into trouble.
