Anyone have a recommendation how to work around this issue?
I have a sharptools dashboard with a HE virtual switch that triggers my goodnight scene (all lights off, doors lock, alarm arm., etc.).
Triggering the switch runs the rule, and then I have the switch set to auto-off after 500ms. This allows the state of the switch to be off in Sharptools and then I can execute it again when I want the rule to run.
Was working great, but ran into a scenerio a few times now where the virtual switch would get executed from Sharptools but seem to get stuck on. I.e. Sharptools didn't get the message that it should turn auto-off. I noticed Sharptools connection errors on the dashboard. As such, Sharptools appears to keep sending the switch on state to HE and causes my goodnight rule to run over and over.
Let's just say my wife is not impressed. Wondering if there is a solution I can program that works around (a button press instead of switch) or other.
