Help me re-register my c7 hub
I have really messed this one up. I have 2 houses, each with a c7 hub. Both hubs were registered under my email address. This has caused me problems with Alexa. My devices were all mixed together and Alexa was having problems with the names. I thought I would setup a new email address and a new hubitat account and then everything would be separate. I'm down to the part where both hubs are still under my first email account. How can I change the email on my hub? It looks like I need to change who it is registered to? In the details of the hub I can see my email address is the admin. So somehow I need to change who the admin is.
Tagging @bobbyD
Check this post to learn how to change the admin account, then reboot the hub to update the new registration (admin) account.
I had already tried that without success but I will go and try it again just in case I did something wrong the first couple of times that I tried it.
All I get is “user not found”
I can sign in with this user name.
OK I did it different this time. I added the new email as a user on the screen and then turned around and added him as the admin and it seemed to have worked. Thanks very much. I was apparently leaving out one part of it.
You ought to delete your publicly visible email above.
Your right. Thanks.
OK that was pretty funny. That time it changed the original hub to my new email. I don’t know what went wrong. I’ll try again. But first I have to get my original hub registered back to my original email.
Yay it finally worked. Got it done. Thanks so much for your help guys.
