Help Making rule with Homeseer and led status
Hi guys i need help with a rule with the Switch Homeseer HS WX300 and the status leds on the switch
i want make 6 differents automatitations/rules (1 on each diferent led) but from the beggining im having complications
background history: on the switch,is set on switch mode,when the load is off the bottom led(#1) light is on and when the load is powered on all the leds turn on on white (i like that)
now...i make one of my rules,when motion is detected,the leds 1 & 2 turn on green,when no motion,turn off (works)... but i want to the led #1 get back to the ¨¨previus mode¨¨bottom led (#1)white while the load is off AND make all leds on in color white when load is turn on
how can i achive this,what i am missing
i hope you understand me,Thanks for your help
Ps: with the current rule,if i turn on the load,all my status leds stay off when usually should be on
i read that when ¨the LEDs should revert to normal mode when all status LEDs are not set¨ but...this does not work for me,why?
