Well - this morning I woke up to this switch finally going "non-responsive". Paddle presses would not do anything. I pressed the "config" switch 3 times and that seemed to put it in pairing mode.
I paired it again with the hub but it would not give me a "replace" option, so I added it with a new name (Kitchen Switch 2) and that's when things got strange. It seems that the switch "replaced' the old switch (I don't see Kitchen Switch in my list of devices) and when I got to look at "In Use By..", I see it listed as being used by MakerAPI - NodeRED and MakerAPI - Homebridge (like the old switch). However, the switch will not respond to commands from the device page. the LED is not on and it will not respond to paddle presses either.
It does show up in z-wave details and in the logs. Any idea on what I can try next?
