Legit nothing working could you help me find out why
I would start by turning on the different logging options in the rule and see what comes out in the logs
nothing shows in logs about the automation
oh nvm it didnt delay just trigger event motion changed had to change
I'm not sure....
Do you want to show the logs?
Or are you saying the issue may be a delay in the change to motion? Rather than the setup of the rule actions?
dev:102023-05-24 02:56:04.208 PMinfoFloor light is off [physical]
dev:72023-05-24 02:55:50.914 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:72023-05-24 02:55:47.204 PMinfoTemp/light/motion sensor: motion is inactive
dev:222023-05-24 02:54:59.126 PMinfoDoor Motion Sensor is active
dev:192023-05-24 02:54:57.802 PMinfoFood Motion Sensor is active
dev:72023-05-24 02:54:57.418 PMinfoTemp/light/motion sensor: motion is active
dev:172023-05-24 02:54:57.171 PMinfoBed Motion Sensor is active
dev:72023-05-24 02:54:47.399 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:72023-05-24 02:54:16.680 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:72023-05-24 02:53:45.990 PMinfoTemp/light/motion sensor: temperature is 80.7°F
dev:72023-05-24 02:53:15.073 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:72023-05-24 02:52:44.478 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:72023-05-24 02:52:13.646 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:172023-05-24 02:52:02.374 PMinfoBed Motion Sensor is inactive
dev:72023-05-24 02:51:12.213 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:102023-05-24 02:51:04.201 PMinfoFloor light is off [physical]
dev:172023-05-24 02:50:58.444 PMinfoBed Motion Sensor is active
dev:72023-05-24 02:50:41.535 PMinfoTemp/light/motion sensor: temperature is 80.6°F
dev:72023-05-24 02:50:41.500 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:192023-05-24 02:50:40.251 PMinfoFood Motion Sensor is inactive
dev:72023-05-24 02:50:10.603 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:72023-05-24 02:48:07.723 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:72023-05-24 02:47:37.070 PMinfoTemp/light/motion sensor: temperature is 80.4°F
dev:72023-05-24 02:47:37.006 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:172023-05-24 02:46:47.137 PMinfoBed Motion Sensor is inactive
dev:72023-05-24 02:46:35.395 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:102023-05-24 02:46:04.226 PMinfoFloor light is off [physical]
dev:172023-05-24 02:45:44.731 PMinfoBed Motion Sensor is active
dev:72023-05-24 02:45:33.960 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:222023-05-24 02:45:05.743 PMinfoDoor Motion Sensor is inactive
dev:72023-05-24 02:45:03.242 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:72023-05-24 02:44:54.530 PMinfoTemp/light/motion sensor: motion is inactive
dev:72023-05-24 02:44:32.114 PMinfoTemp/light/motion sensor: temperature is 80.4°F
dev:72023-05-24 02:44:32.076 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:72023-05-24 02:43:59.837 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:192023-05-24 02:43:34.437 PMinfoFood Motion Sensor is active
dev:72023-05-24 02:43:28.635 PMinfoTemp/light/motion sensor: illuminance is 58lux
app:542023-05-24 02:43:25.457 PMinfoAction: END-IF
app:542023-05-24 02:43:25.449 PMinfoAction: Dim: Lmap, left lamp, right lamp, Wiz RGBW Light on 192.168.0.14: 100 --> fade: 2 (skipped)
app:542023-05-24 02:43:25.439 PMinfoAction: ELSE-IF (Time between 10:00 PM and Sunrise+45 minutes(6:06 AM)(F) AND
Lmap, left lamp, right lamp(on, on, on) all on(T) AND
Door contact Sensor contact closed(T) [FALSE]) THEN (skipping)
app:542023-05-24 02:43:25.386 PMinfoAction: Dim: Lmap, left lamp, right lamp, Wiz RGBW Light on 192.168.0.14: 20 --> fade: 2 (skipped)
app:542023-05-24 02:43:25.373 PMinfoAction: IF (Door contact Sensor contact open(F) AND
Lmap, left lamp, right lamp(on, on, on) all on(T) [FALSE]) THEN (skipping)
app:542023-05-24 02:43:25.159 PMinfoTriggered: Door contact Sensor contact changed
app:542023-05-24 02:43:25.088 PMinfoEvent: Door contact Sensor contact closed
dev:82023-05-24 02:43:24.976 PMinfoDoor contact Sensor is closed
dev:72023-05-24 02:43:23.170 PMinfoTemp/light/motion sensor: motion is active
dev:222023-05-24 02:43:22.533 PMinfoDoor Motion Sensor is active
dev:72023-05-24 02:42:26.902 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:172023-05-24 02:42:21.626 PMinfoBed Motion Sensor is inactive
dev:192023-05-24 02:42:16.952 PMinfoFood Motion Sensor is inactive
dev:222023-05-24 02:34:19.162 PMinfoDoor Motion Sensor is inactive
dev:72023-05-24 02:33:52.594 PMinfoTemp/light/motion sensor: motion is inactive
dev:72023-05-24 02:33:33.111 PMinfoTemp/light/motion sensor: illuminance is 66lux
dev:172023-05-24 02:33:03.154 PMinfoBed Motion Sensor is active
dev:72023-05-24 02:33:01.523 PMinfoTemp/light/motion sensor: motion is active
dev:72023-05-24 02:32:31.939 PMinfoTemp/light/motion sensor: illuminance is 65lux
dev:172023-05-24 02:32:17.517 PMinfoBed Motion Sensor is inactive
dev:72023-05-24 02:32:07.198 PMinfoTemp/light/motion sensor: motion is inactive
dev:72023-05-24 02:32:00.668 PMinfoTemp/light/motion sensor: temperature is 79.5°F
dev:72023-05-24 02:32:00.648 PMinfoTemp/light/motion sensor: illuminance is 66lux
dev:72023-05-24 02:31:28.394 PMinfoTemp/light/motion sensor: illuminance is 65lux
dev:72023-05-24 02:31:12.873 PMinfoTemp/light/motion sensor: motion is active
dev:102023-05-24 02:31:06.569 PMinfoFloor light is off [physical]
dev:72023-05-24 02:30:59.400 PMinfoTemp/light/motion sensor: motion is inactive
dev:72023-05-24 02:30:55.864 PMinfoTemp/light/motion sensor: illuminance is 63lux
dev:72023-05-24 02:30:23.773 PMinfoTemp/light/motion sensor: illuminance is 60lux
dev:72023-05-24 02:29:52.049 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:192023-05-24 02:29:40.221 PMinfoFood Motion Sensor is active
dev:172023-05-24 02:29:34.332 PMinfoBed Motion Sensor is active
dev:72023-05-24 02:29:24.761 PMinfoTemp/light/motion sensor: motion is active
dev:72023-05-24 02:29:19.305 PMinfoTemp/light/motion sensor: illuminance is 60lux
dev:222023-05-24 02:29:19.165 PMinfoDoor Motion Sensor is active
dev:72023-05-24 02:28:48.590 PMinfoTemp/light/motion sensor: temperature is 79.8°F
dev:102023-05-24 02:26:06.573 PMinfoFloor light is off [physical]
dev:72023-05-24 02:25:44.031 PMinfoTemp/light/motion sensor: temperature is 80.0°F
dev:72023-05-24 02:22:39.463 PMinfoTemp/light/motion sensor: temperature is 80.2°F
dev:102023-05-24 02:21:06.551 PMinfoFloor light is off [physical]
dev:72023-05-24 02:19:34.960 PMinfoTemp/light/motion sensor: temperature is 80.4°F
dev:72023-05-24 02:16:30.488 PMinfoTemp/light/motion sensor: temperature is 80.4°F
dev:102023-05-24 02:16:06.577 PMinfoFloor light is off [physical]
dev:72023-05-24 02:13:25.952 PMinfoTemp/light/motion sensor: temperature is 80.4°F
dev:102023-05-24 02:11:06.589 PMinfoFloor light is off [physical]
dev:72023-05-24 02:10:21.454 PMinfoTemp/light/motion sensor: temperature is 80.2°F
dev:72023-05-24 02:07:16.885 PMinfoTemp/light/motion sensor: temperature is 80.2°F
dev:102023-05-24 02:06:06.517 PMinfoFloor light is off [physical]
dev:72023-05-24 02:04:12.341 PMinfoTemp/light/motion sensor: temperature is 80.2°F
dev:72023-05-24 02:01:07.777 PMinfoTemp/light/motion sensor: temperature is 80.0°F
dev:102023-05-24 02:01:06.597 PMinfoFloor light is off [physical]
dev:72023-05-24 01:58:03.180 PMinfoTemp/light/motion sensor: temperature is 80.0°F
dev:102023-05-24 01:56:06.538 PMinfoFloor light is off [physical]
dev:72023-05-24 01:54:58.612 PMinfoTemp/light/motion sensor: temperature is 80.0°F
dev:72023-05-24 01:51:54.110 PMinfoTemp/light/motion sensor: temperature is 80.2°F
dev:222023-05-24 01:51:45.227 PMinfoDoor Motion Sensor is inactive
dev:72023-05-24 01:51:09.481 PMinfoTemp/light/motion sensor: motion is inactive
dev:102023-05-24 01:51:06.493 PMinfoFloor light is off [physical]
dev:72023-05-24 01:50:38.438 PMinfoTemp/light/motion sensor: motion is active
dev:222023-05-24 01:50:38.352 PMinfoDoor Motion Sensor is active
dev:72023-05-24 01:48:48.406 PMinfoTemp/light/motion sensor: temperature is 80.4°F
dev:222023-05-24 01:47:04.310 PMinfoDoor Motion Sensor is inactive
dev:172023-05-24 01:46:58.096 PMinfoBed Motion Sensor is inactive
dev:72023-05-24 01:46:29.643 PMinfoTemp/light/motion sensor: motion is inactive
dev:72023-05-24 01:46:14.106 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:102023-05-24 01:46:06.551 PMinfoFloor light is off [physical]
dev:72023-05-24 01:45:58.605 PMinfoTemp/light/motion sensor: motion is active
dev:222023-05-24 01:45:56.006 PMinfoDoor Motion Sensor is active
dev:72023-05-24 01:45:44.310 PMinfoTemp/light/motion sensor: temperature is 80.6°F
dev:72023-05-24 01:45:44.291 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:172023-05-24 01:45:26.357 PMinfoBed Motion Sensor is active
dev:172023-05-24 01:43:50.209 PMinfoBed Motion Sensor is inactive
dev:72023-05-24 01:43:41.298 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:172023-05-24 01:42:47.670 PMinfoBed Motion Sensor is active
dev:72023-05-24 01:42:39.913 PMinfoTemp/light/motion sensor: temperature is 80.9°F
dev:172023-05-24 01:42:07.716 PMinfoBed Motion Sensor is inactive
dev:72023-05-24 01:41:38.308 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:102023-05-24 01:41:06.481 PMinfoFloor light is off [physical]
dev:172023-05-24 01:41:05.308 PMinfoBed Motion Sensor is active
dev:72023-05-24 01:39:35.546 PMinfoTemp/light/motion sensor: temperature is 81.1°F
dev:72023-05-24 01:39:35.526 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:72023-05-24 01:38:33.955 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:72023-05-24 01:36:31.171 PMinfoTemp/light/motion sensor: temperature is 80.9°F
dev:102023-05-24 01:36:06.474 PMinfoFloor light is off [physical]
dev:172023-05-24 01:34:36.929 PMinfoBed Motion Sensor is inactive
dev:72023-05-24 01:34:28.159 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:72023-05-24 01:33:57.464 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:172023-05-24 01:33:34.541 PMinfoBed Motion Sensor is active
dev:72023-05-24 01:33:26.783 PMinfoTemp/light/motion sensor: temperature is 80.9°F
dev:72023-05-24 01:33:26.753 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:102023-05-24 01:31:06.509 PMinfoFloor light is off [physical]
dev:72023-05-24 01:30:22.337 PMinfoTemp/light/motion sensor: temperature is 80.7°F
dev:172023-05-24 01:29:36.915 PMinfoBed Motion Sensor is inactive
dev:172023-05-24 01:27:51.980 PMinfoBed Motion Sensor is active
dev:72023-05-24 01:27:17.902 PMinfoTemp/light/motion sensor: temperature is 80.7°F
dev:102023-05-24 01:26:06.463 PMinfoFloor light is off [physical]
dev:82023-05-24 01:26:04.954 PMinfoDoor contact Sensor battery is 100%
dev:72023-05-24 01:24:13.473 PMinfoTemp/light/motion sensor: temperature is 80.7°F
dev:72023-05-24 01:24:13.454 PMinfoTemp/light/motion sensor: illuminance is 62lux
dev:72023-05-24 01:23:42.564 PMinfoTemp/light/motion sensor: illuminance is 63lux
dev:222023-05-24 01:23:37.211 PMinfoDoor Motion Sensor is inactive
dev:172023-05-24 01:23:16.109 PMinfoBed Motion Sensor is inactive
dev:192023-05-24 01:23:14.760 PMinfoFood Motion Sensor is inactive
dev:72023-05-24 01:22:51.136 PMinfoTemp/light/motion sensor: motion is inactive
dev:72023-05-24 01:22:40.591 PMinfoTemp/light/motion sensor: illuminance is 62lux
app:542023-05-24 01:22:20.037 PMinfoAction: END-IF
app:542023-05-24 01:22:20.034 PMinfoAction: Dim: Lmap, left lamp, right lamp, Wiz RGBW Light on 192.168.0.14: 100 --> fade: 2 (skipped)
app:542023-05-24 01:22:20.030 PMinfoAction: ELSE-IF (Time between 10:00 PM and Sunrise+45 minutes(6:06 AM)(F) AND
Door contact Sensor contact closed(F) [FALSE]) THEN (skipping)
app:542023-05-24 01:22:19.894 PMinfoAction: Dim: Lmap, left lamp, right lamp, Wiz RGBW Light on 192.168.0.14: 20 --> fade: 2 (skipped)
app:542023-05-24 01:22:19.889 PMinfoAction: IF (Door contact Sensor contact open(T) AND
app:542023-05-24 01:22:19.794 PMinfoTriggered: Door contact Sensor contact changed
app:542023-05-24 01:22:19.765 PMinfoEvent: Door contact Sensor contact open
dev:82023-05-24 01:22:19.698 PMinfoDoor contact Sensor is open
dev:72023-05-24 01:22:08.869 PMinfoTemp/light/motion sensor: illuminance is 61lux
dev:222023-05-24 01:22:02.590 PMinfoDoor Motion Sensor is active
dev:72023-05-24 01:22:02.368 PMinfoTemp/light/motion sensor: motion is active
dev:172023-05-24 01:22:02.087 PMinfoBed Motion Sensor is active
dev:192023-05-24 01:21:59.885 PMinfoFood Motion Sensor is active
dev:192023-05-24 01:21:37.468 PMinfoFood Motion Sensor is inactive
dev:102023-05-24 01:21:06.455 PMinfoFloor light is off [physical]
dev:72023-05-24 01:21:06.152 PMinfoTemp/light/motion sensor: temperature is 80.7°F
dev:72023-05-24 01:20:35.234 PMinfoTemp/light/motion sensor: illuminance is 63lux
dev:72023-05-24 01:20:04.515 PMinfoTemp/light/motion sensor: illuminance is 64lux
dev:72023-05-24 01:19:03.073 PMinfoTemp/light/motion sensor: illuminance is 63lux
dev:72023-05-24 01:18:01.663 PMinfoTemp/light/motion sensor: temperature is 80.6°F
dev:72023-05-24 01:17:30.744 PMinfoTemp/light/motion sensor: illuminance is 64lux
dev:32023-05-24 01:17:17.900 PMinfoleft lamp level was set to 100%
dev:42023-05-24 01:17:12.965 PMinforight lamp was turned on
dev:32023-05-24 01:17:12.900 PMinfoleft lamp level was set to 1%
