So i have been converting my Graphs to WebCore and using WebCore LTS to store device values which has been great.
Problem statement: I cannot get a Global Hubitat Variable (the sump counter) to store in Webcore LTS - it only works with devices. So I was going to try create a "Fuel Stream" from this to be able to graph it.
In my Piston, i use the "Append to Fuel Stream" action to get the global variable into a Fuelstream which seems to work fine in the Piston. However anytime i go into the Hubitat Webcore graphing engine i keep getting "NO FUEL STREAMS FOUND".
Question 1: How do i get Fuel Streams to show up back in Hubitat Webcore graphing? I've turned the "Local Fuel Streams setting" on and off and no difference.
Question 2: How do i log this in LTS?
No fuel streams found
