Help deleting a Linux “program”
I did this and now I want to totally delete everything I did. Thank you
Add Sonarr's repository to your software source
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0xA236C58F409091A18ACA53CBEBFF6B99D9B78493
echo "deb http://apt.sonarr.tv/ master main" | sudo tee /etc/apt/sources.list.d/sonarr.list
If you have issues with the repo being https you can install the apt-transport-https package or switch to http
Install/Update Sonarr
sudo apt update
sudo apt install nzbdrone
Start Sonarr
mono --debug /opt/NzbDrone/NzbDrone.exe
I'm assuming you're using Ubuntu, or at least something Debian-based with APT as your installation instructions indicate. In that case, I'd recommend reading this answer (a bit dated but will still work) to find the best option for you:
(Here, "nzbdrone" is "packagename".)
Casual Googling tells me you may also wish to delete /opt/NzbDrone if it still exists after this, so:
sudo rm -r /opt/NzbDrone
After doing this, you'll still have the repo listed in your sources and their key added. This isn't really a problem; it just makes it available to install if you explicitly do so again in the future (so you could skip that first step). If that bothers you:
Thank you, sir
Just have to insert my worthless 2 cents....
Be very mindful when using "rm -r" , watched an "experienced" admin run one from root. I usually end up changing into the parent directory and just use "rm -r foldername".
