Hi,
I found a driver for Philio PAN04 Dual relay switch:
Would love to find or get help converting it to Parent with 2 child objects (switches) so i can have 2 tiles in dashboard and 2 devices on google home...
Any help would be appreciated,
Lior
Have you tried using some of the built-in driver types to see if any of them will work with this device? There is a Generic Z-Wave Plus MultiSwitch driver that might fit the bill, if you haven’t already tried it. Make sure you click Configure after changing and saving the driver type. It’s worth a shot
Tried Many of the Build in drivers, most of the times i didn't get any child devices nor some of them even light of the switch...
at the end this driver helped:
if anyone needs a driver for Philio PAN04 Dual switch, this one works and makes two child objects...
Thanks everyone
