Help! All Z-Wave devices have stopped responding
I got the three that paired S0 excluded and reincluded non secure. Each one took me 3 tries to get them to do it. I noticed when they were paired S0 they all showed an S2 value of 125, that's why I thought they paired S2 originally.
Also in the thread linked above (inovelli forum) there was discussion of issues updating using the hubutat firmware updater. I was able to get all of them updated that way, but it took several tries on each one to get them to all update and show the correct version number.
All of my Z-Wave devices went unresponsive as well (C-7 Hub). I can't fix it. I tried a reboot/repair and nothing is resolving it. Please advise.
These are all of my devices. Does anything stand out?
0x0A looks like it may be a ghost…
I tried pressing "Remove" but it refreshes the page and it is still there.
I’m betting the log says that the device responded to the ping. Other than the Front door do you have another zwave lock? If not may want to try taking the batteries out of the front door lock and seeing if a refresh and remove will then work.
Yea I also have Z-Wave August Lock on the garage. I removed batteries from both and tried a "Refresh" & "Remove" but that didn't work. I'll try a reboot now and repeat.
Update: Reboot didn't help.
in past release i have found to make sure to remove power or batteries from device.. then reboot hub and then when it first comes back up try remove a few times..
I removed it and it looks like Z-Wave is working now! Rebooted a few times, shutdowned the hub for a few mins, unplugged it and plugged it back in.
Thank you @thebearmay & @kahn-hubitat for your help!
