Hi all,
I have a few of these and was hoping to use one with hubitat for power monitoring (want to know when my air con is on).
Can't seem to locate a driver. I managed to add it as a standard device, then alter to a 'generic z wave outlet' which allows simple on/off but no power monitoring.
Can anyone please assist?
Here's the product page:
http://manuals-backend.z-wave.info/make.php?lang=en&sku=HS2SK-Z&cert=ZC10-17055579
TIA! =)
try neo coolcam plug driver?
Done, thanks. It does seem to report power, but doesn't update unless I click refresh.
Any tips?
Update the power reporting?
Come again?
Can't code to save my life. If that's what you're referring to. Hah.
The parameters, on how they report. The cheap z-wave ones will report for example 5% difference. The more expensive ones you can adjust the value.
I think the driver only partially works. I can do a simple webcore script to 'refresh' periodically, which shows the then-current value just fine. But unless it's manually refreshed in this way, then the values don't change.
You might need a custom driver then. I've binned all my cheap z-wave plugs as they can end up very chatty
Any pointers to a cheap zigbee one, perhaps?
That's an easy one
basic on/off == Ikea. Energy monitoring ST Plug.
Ah awesome. Already knew about the ikea ones, I've got loads.
Fortunately I retained my Samsung plugs before binning that piece of crap hub when I came here. Class. Thanks for the help.
Would be ace if anyone had knocked up a custom driver for thr heiman ones too. I've got a fair few. =p
Righto. Appears that my zwave mesh was actually funky.
Did a repair, all good. Although energy updates don't seem to be possible for periods shorter than approx 30 seconds, regardless of what the config options show.
Cheers!
