Yes, its not a nice flash from memory, more like an alarm!
Have you already got a bit of an integration of your own? Or were just curious?
Will share mine tomorrow for first debugging feedback.
I've just created a very simple driver to switch stats between frost on and off so that I can control it's usage when people are in the house and motion in certain rooms. I've just put the flash in when it turns on a stat. Not too bad, as the blue backlight is quite pleasant and means I can see the device turn on from across the room.
It is nothing compared to your fully comprehensive system.
Just created it following the quick experiment from the earlier post.
Initial beta posted below - Will create a proper thread for it shortly, but feedback welcome as I have done minimal testing other than to confirm it works! For now you need to add both device handlers, then create a new virtual device of the Neohub Bridge device and fill in the IP address of your Neohub, finally you can press Getthermostats and the children will appear, with basic ability to control key attributes.
EDIT: Removed and placed in the thread below
Really exciting, will try it out and give you feedback tonight.
Function has definitely gone before design! But making it look better should be easier, and this way automations can start building ontop already.
all seems to work fine! Not sure what the password field in preferences is for though... a remnant of some experiment?
Yup, ignore that, just an old field. Thanks
Job well done, seems to work well. Interface options are more limited on hubitat than smartthings
Hi @cjcharles, does your implementation work with google home?
Hi
I have this correctly connected to my NeoHub bridge and can see the variables and current states, however changing the values in the virtual device within Hubitat doesn't update the Heatmiser Bridge settings. i.e. Changing the heatingsetpoint to 20.0 from 21 shows correctly in the virtual device but doesn't update the thermostat. Am I being stupid here? (Wouldn't be the first time!)
Edit, I got confused about the ST forums. Will check this out myself now
